Encrypted storage with TrustZone
2,627 次查看
brucezhao
    AN12714 (i.MX Encrypted Storage Using CAAM Secure Keys) document describes Encrypted storage with CAAM.
    My question is that if I want to use CSU(Central Security Unit) to limit only OP-TEE can access CAAM, then CAAM can not be accessed by Normal world directly. I mean how to implement encrypted storage with OP-TEE, which uses OTPMK as root key by CAAM.
    Thanks.
2,614 次查看
Harvey021
Hi @brucezhao
OP-TEE itself is secure world, which should be able to access CAAM. AN12714 here mainly uses the kernel module DM-Crypt, which uses CAAM's secure key to implement disk encryption, and does not implement the requirements you mentioned.
Harvey
Harvey
2,599 次查看
brucezhao
Hi Harvey, I got it. Thank you for your reply.
2,615 次查看
Harvey021
Hi @brucezhao
Harvey
Harvey
