Encoding MJPEG
Encoding MJPEG
1,897 次查看
ajj
I'm looking for the lowest cost solution to encode MJPEG at 15fps at VGA or WVGA resolution.  Does the MX28 have enough speed to do this in software?  Or do I need to use a device with a hardware encoder?
Andy
标记 (1)
1,748 次查看
saurabh206
Senior Contributor III
Have you got your solution?
Which types of camera are you using in your system?
Camera gives output in YCbCr ro RGB format output?
Saurabh
1,748 次查看
hake
it depends on your MJPEG resolution, you can port mencoder to have a try.
