Enable Persistent WiFi on NXP FRDM IMX93 Board
1,158 次查看
armwaheed
Here are instructions to configure the NXP board to connect to a specific WiFi network on boot.
  1. Log in to Linux on the board, as root
  2. Create a wpa_supplicant.conf:
    touch /etc/wpa_supplicant.conf
    nano /etc/wpa_supplicant.conf
    Enter your WiFi credentials into the wpa_supplicant.conf file:
    ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
    update_config=1
    network={
        ssid="YOUR_SSID"
        psk="YOUR_PASSWORD"
        key_mgmt=WPA-PSK
  3. Test the wpa_supplicant.conf file:
    modprobe moal mod_para=nxp/wifi_mod_para.conf
    ifconfig mlan0 up
    wpa_supplicant -B -i mlan0 -c /etc/wpa_supplicant.conf
    udhcpc -i mlan0
    • mlan0 is the WiFi interface on i.MX93
    • If this connects to WiFi, we’re ready for automation
  4. Configure DNS server IP addresses, so that the NXP board can resolve Internet addresses:
    touch /usr/share/udhcpc/default.script
    nano /usr/share/udhcpc/default.script
    and add in the following udhcpc script:
    #!/bin/sh
    # udhcpc script
    case "$1" in
        deconfig)
            ip addr flush dev $interface
        bound|renew)
            ip addr add $ip/$subnet dev $interface
            ip route add default via $router
            echo "nameserver 8.8.8.8" > /etc/resolv.conf
            echo "nameserver 1.1.1.1" >> /etc/resolv.conf
    esac
    Make the default.script executable:
    chmod +x /usr/share/udhcpc/default.script
  5. Create a nxp-wifi-setup.sh script:
    touch /usr/bin/nxp-wifi-setup.sh
    nano /usr/bin/nxp-wifi-setup.sh
    and add in the following lines:
    #!/bin/sh
    # Load WiFi driver
    /usr/sbin/modprobe moal mod_para=nxp/wifi_mod_para.conf
    # Bring interface up
    /usr/bin/ifconfig mlan0 up
    # Connect to WiFi
    /usr/sbin/wpa_supplicant -B -i mlan0 -c /etc/wpa_supplicant.conf
    # Obtain DHCP IP + DNS
    /usr/sbin/udhcpc -i mlan0 -s /usr/share/udhcpc/default.script
    Make the nxp-wifi-setup.sh executable:
    chmod +x /usr/bin/nxp-wifi-setup.sh
  6. Create a nxp-wifi-setup.service:
    touch /etc/systemd/system/nxp-wifi-setup.service
    nano /etc/systemd/system/nxp-wifi-setup.service
    Enter the following systemd commands into the nxp-wifi-setup.service file:
    [Unit]
    Description=WiFi Setup for NXP FRDM i.MX93
    After=network.target
    [Service]
    Type=oneshot
    ExecStart=/usr/bin/nxp-wifi-setup.sh
    RemainAfterExit=yes
    [Install]
    WantedBy=multi-user.target
  7. Create a wpa_supplicant.service:
    touch /etc/systemd/system/wpa_supplicant.service
    nano /etc/systemd/system/wpa_supplicant.service
    Enter the following systemd commands into the wpa_supplicant.service file:
    [Unit]
    Description=WPA Supplicant daemon
    [Service]
    Type=simple
    ExecStart=/usr/sbin/wpa_supplicant -i mlan0 -c /etc/wpa_supplicant.conf
    Restart=always
    [Install]
  8. Enable and Start the nxp-wifi-setup.service:
    systemctl daemon-reload
    systemctl enable nxp-wifi-setup.service wpa_supplicant.service
    systemctl start nxp-wifi-setup.service wpa_supplicant.service
  9. Check status:
systemctl status nxp-wifi-setup.service
systemctl status wpa_supplicant.service
and confirm Internet connectivity:
curl -I http://www.example.com
1,132 次查看
Zhiming_Liu
Hi @armwaheed
Thanks for sharing !
Zhiming
%3CLINGO-SUB%20id%3D%22lingo-sub-2170713%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6%20FRDM%20IMX93%20%E6%9D%BF%E4%B8%8A%E5%90%AF%E7%94%A8%E6%8C%81%E4%B9%85%20WiFi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2170713%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E9%85%8D%E7%BD%AE%E6%81%A9%E6%99%BA%E6%B5%A6%E6%9D%BF%E4%BB%A5%E5%9C%A8%E5%90%AF%E5%8A%A8%E6%97%B6%E8%BF%9E%E6%8E%A5%E5%88%B0%E7%89%B9%E5%AE%9AWiFi%E7%BD%91%E7%BB%9C%E7%9A%84%E8%AF%B4%E6%98%8E%E3%80%82%3C%2FP%3E%3COL%3E%3CLI%3E%3CP%3E%E4%BB%A5%3CSPAN%3E%3C%2FSPAN%3E%20root%20%E8%BA%AB%E4%BB%BD%E7%99%BB%E5%BD%95%E6%9D%BF%E4%B8%8A%E7%9A%84%20Linux%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E5%88%9B%E5%BB%BA%3CSPAN%3E%20%3C%2FSPAN%3Ewpa_supplicant.conf%EF%BC%9A%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CPRE%20translate%3D%22no%22%3Etouch%20%2Fetc%2Fwpa_supplicant.conf%0Anano%20%2Fetc%2Fwpa_supplicant.conf%3C%2FPRE%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%E5%9C%A8%3CSPAN%3E%20%3C%2FSPAN%3Ewpa_supplicant.conf%20%E4%B8%AD%E8%BE%93%E5%85%A5%20WiFi%20%E5%87%AD%E6%8D%AE%3CSPAN%3E%20%3C%2FSPAN%3E%E9%94%89%E5%88%80%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CPRE%20translate%3D%22no%22%3Ectrl_interface%3DDIR%3D%2Fvar%2Frun%2Fwpa_supplicant%20GROUP%3Dnetdev%0Aupdate_config%3D1%0A%0Anetwork%3D%7B%0A%20%20%20%20ssid%3D%22YOUR_SSID%22%0A%20%20%20%20psk%3D%22YOUR_PASSWORD%22%0A%20%20%20%20key_mgmt%3DWPA-PSK%0A%7D%3C%2FPRE%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E6%B5%8B%E8%AF%95%3CSPAN%3E%20%3C%2FSPAN%3Ewpa_supplicant.conf%3CSPAN%3E%20%3C%2FSPAN%3E%E9%94%89%E5%88%80%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CPRE%20translate%3D%22no%22%3Emodprobe%20moal%20mod_para%3Dnxp%2Fwifi_mod_para.conf%0Aifconfig%20mlan0%20up%0Awpa_supplicant%20-B%20-i%20mlan0%20-c%20%2Fetc%2Fwpa_supplicant.conf%0Audhcpc%20-i%20mlan0%3C%2FPRE%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CUL%3E%3CLI%3Emlan0%20%E6%98%AF%20i.MX93%20%E4%B8%8A%E7%9A%84%20WiFi%20%E6%8E%A5%E5%8F%A3%3C%2FLI%3E%3CLI%3E%E5%A6%82%E6%9E%9C%E5%AE%83%E8%83%BD%E8%BF%9E%E6%8E%A5%E5%88%B0%20WiFi%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B0%B1%E5%8F%AF%E4%BB%A5%E5%AE%9E%E7%8E%B0%E8%87%AA%E5%8A%A8%E5%8C%96%E4%BA%86%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E9%85%8D%E7%BD%AE%20DNS%20%E6%9C%8D%E5%8A%A1%E5%99%A8%20IP%20%E5%9C%B0%E5%9D%80%EF%BC%8C%E4%BB%A5%E4%BE%BF%E6%81%A9%E6%99%BA%E6%B5%A6%E6%9D%BF%E5%8F%AF%E4%BB%A5%E8%A7%A3%E6%9E%90%E4%BA%92%E8%81%94%E7%BD%91%E5%9C%B0%E5%9D%80%EF%BC%9A%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CPRE%20translate%3D%22no%22%3Etouch%20%2Fusr%2Fshare%2Fudhcpc%2Fdefault.script%0Anano%20%2Fusr%2Fshare%2Fudhcpc%2Fdefault.script%3C%2FPRE%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%E5%B9%B6%E6%B7%BB%E5%8A%A0%E4%BB%A5%E4%B8%8B%3CSPAN%3E%20%3C%2FSPAN%3Eudhcpc%3CSPAN%3E%20%3C%2FSPAN%3E%E8%84%9A%E6%9C%AC%EF%BC%9A%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CPRE%20translate%3D%22no%22%3E%23!%2Fbin%2Fsh%0A%23%20udhcpc%20script%0Acase%20%22%241%22%20in%0A%20%20%20%20deconfig)%0A%20%20%20%20%20%20%20%20ip%20addr%20flush%20dev%20%24interface%0A%20%20%20%20%20%20%20%20%3B%3B%0A%20%20%20%20bound%7Crenew)%0A%20%20%20%20%20%20%20%20ip%20addr%20add%20%24ip%2F%24subnet%20dev%20%24interface%0A%20%20%20%20%20%20%20%20ip%20route%20add%20default%20via%20%24router%0A%20%20%20%20%20%20%20%20echo%20%22nameserver%208.8.8.8%22%20%26gt%3B%20%2Fetc%2Fresolv.conf%0A%20%20%20%20%20%20%20%20echo%20%22nameserver%201.1.1.1%22%20%26gt%3B%26gt%3B%20%2Fetc%2Fresolv.conf%0A%20%20%20%20%20%20%20%20%3B%3B%0Aesac%3C%2FPRE%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%E5%88%B6%E4%BD%9C%3CSPAN%3E%20%3C%2FSPAN%3Edefault.script%3CSPAN%3E%20%3C%2FSPAN%3E%E5%8F%AF%E6%89%A7%E8%A1%8C%EF%BC%9A%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CPRE%20translate%3D%22no%22%3Echmod%20%2Bx%20%2Fusr%2Fshare%2Fudhcpc%2Fdefault.script%3C%2FPRE%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E5%88%9B%E5%BB%BA%3CSPAN%3E%20%3C%2FSPAN%3Enxp-wifi-setup.sh%3CSPAN%3E%20%3C%2FSPAN%3E%E5%89%A7%E6%9C%AC%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CPRE%20translate%3D%22no%22%3Etouch%20%2Fusr%2Fbin%2Fnxp-wifi-setup.sh%0Anano%20%2Fusr%2Fbin%2Fnxp-wifi-setup.sh%3C%2FPRE%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%E5%B9%B6%E6%B7%BB%E5%8A%A0%E4%BB%A5%E4%B8%8B%E5%87%A0%E8%A1%8C%EF%BC%9A%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CPRE%20translate%3D%22no%22%3E%23!%2Fbin%2Fsh%0A%23%20Load%20WiFi%20driver%0A%2Fusr%2Fsbin%2Fmodprobe%20moal%20mod_para%3Dnxp%2Fwifi_mod_para.conf%0A%0A%23%20Bring%20interface%20up%0A%2Fusr%2Fbin%2Fifconfig%20mlan0%20up%0A%0A%23%20Connect%20to%20WiFi%0A%2Fusr%2Fsbin%2Fwpa_supplicant%20-B%20-i%20mlan0%20-c%20%2Fetc%2Fwpa_supplicant.conf%0A%0A%23%20Obtain%20DHCP%20IP%20%2B%20DNS%0A%2Fusr%2Fsbin%2Fudhcpc%20-i%20mlan0%20-s%20%2Fusr%2Fshare%2Fudhcpc%2Fdefault.script%3C%2FPRE%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%E5%88%B6%E4%BD%9C%3CSPAN%3E%20%3C%2FSPAN%3Enxp-wifi-setup.sh%3CSPAN%3E%20%3C%2FSPAN%3E%E5%8F%AF%E6%89%A7%E8%A1%8C%EF%BC%9A%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CPRE%20translate%3D%22no%22%3Echmod%20%2Bx%20%2Fusr%2Fbin%2Fnxp-wifi-setup.sh%3C%2FPRE%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E5%88%9B%E5%BB%BA%3CSPAN%3E%20%3C%2FSPAN%3Enxp-wifi-setup.service%EF%BC%9A%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CPRE%20translate%3D%22no%22%3Etouch%20%2Fetc%2Fsystemd%2Fsystem%2Fnxp-wifi-setup.service%0Anano%20%2Fetc%2Fsystemd%2Fsystem%2Fnxp-wifi-setup.service%3C%2FPRE%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%E5%9C%A8%3CSPAN%3E%20%3C%2FSPAN%3Enxp-wifi-setup.service%20%E4%B8%AD%E8%BE%93%E5%85%A5%E4%BB%A5%E4%B8%8B%20systemd%20%E5%91%BD%E4%BB%A4%3CSPAN%3E%20%3C%2FSPAN%3E%E9%94%89%E5%88%80%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CPRE%20translate%3D%22no%22%3E%5BUnit%5D%0ADescription%3DWiFi%20Setup%20for%20NXP%20FRDM%20i.MX93%0AAfter%3Dnetwork.target%0A%0A%5BService%5D%0AType%3Doneshot%0AExecStart%3D%2Fusr%2Fbin%2Fnxp-wifi-setup.sh%0ARemainAfterExit%3Dyes%0A%0A%5BInstall%5D%0AWantedBy%3Dmulti-user.target%3C%2FPRE%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E5%88%9B%E5%BB%BA%3CSPAN%3E%20%3C%2FSPAN%3Ewpa_supplicant.service%EF%BC%9A%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CPRE%20translate%3D%22no%22%3Etouch%20%2Fetc%2Fsystemd%2Fsystem%2Fwpa_supplicant.service%0Anano%20%2Fetc%2Fsystemd%2Fsystem%2Fwpa_supplicant.service%3C%2FPRE%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%E5%9C%A8%3CSPAN%3E%20%3C%2FSPAN%3Ewpa_supplicant.service%20%E4%B8%AD%E8%BE%93%E5%85%A5%E4%BB%A5%E4%B8%8B%20systemd%20%E5%91%BD%E4%BB%A4%3CSPAN%3E%20%3C%2FSPAN%3E%E9%94%89%E5%88%80%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CPRE%20translate%3D%22no%22%3E%5BUnit%5D%0ADescription%3DWPA%20Supplicant%20daemon%0AAfter%3Dnetwork.target%0A%0A%5BService%5D%0AType%3Dsimple%0AExecStart%3D%2Fusr%2Fsbin%2Fwpa_supplicant%20-i%20mlan0%20-c%20%2Fetc%2Fwpa_supplicant.conf%0ARestart%3Dalways%0A%0A%5BInstall%5D%0AWantedBy%3Dmulti-user.target%3C%2FPRE%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E5%90%AF%E7%94%A8%E5%B9%B6%E5%90%AF%E5%8A%A8%3CSPAN%3E%20%3C%2FSPAN%3Enxp-wifi-setup.service%EF%BC%9A%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CPRE%20translate%3D%22no%22%3Esystemctl%20daemon-reload%0Asystemctl%20enable%20nxp-wifi-setup.service%20wpa_supplicant.service%0Asystemctl%20start%20nxp-wifi-setup.service%20wpa_supplicant.service%3C%2FPRE%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E6%A3%80%E6%9F%A5%E7%8A%B6%E6%80%81%EF%BC%9A%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CDIV%20class%3D%22%22%3E%3CPRE%20translate%3D%22no%22%3Esystemctl%20status%20nxp-wifi-setup.service%0Asystemctl%20status%20wpa_supplicant.service%3C%2FPRE%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%E5%B9%B6%E7%A1%AE%E8%AE%A4%E4%BA%92%E8%81%94%E7%BD%91%E8%BF%9E%E6%8E%A5%EF%BC%9A%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CPRE%20translate%3D%22no%22%3Ecurl%20-I%20http%3A%2F%2Fwww.example.com%3C%2FPRE%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2170815%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Enable%20Persistent%20WiFi%20on%20NXP%20FRDM%20IMX93%20Board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2170815%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F254072%22%20target%3D%22_blank%22%3E%40armwaheed%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%88%86%E4%BA%AB%EF%BC%81%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%9C%80%E7%BE%8E%E5%A5%BD%E7%9A%84%E7%A5%9D%E6%84%BF%EF%BC%8C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E
