Embedded linux and i.mx books.
12,473 次查看
ssinfod
I want to use embedded Linux (yocto) on the i.mx 6 processor. I already booted some dev kit with yocto on it.
Now, I'm looking for some text book that explains how to use the peripheral of the i.mx 6 with Linux. (For example: SPI, I2C, Timer, ATD, Timer, CAN, UART, etc.)
I'm coming from the microcontroller world (Freescale HCS08, HCS12, etc..) and I am a little lost regarding these subjects.
Can anyone suggest me some good text books or tutorial on how to use the i.mx peripheral inside Linux ?
ssinfod
标签 (5)
11,406 次查看
jimmychan
You can find the path of the driver source code in i.MX6 Linux Reference Manual.
For the example on how to use it, you can take the imx-test for reference. (<Yocto_BuildDir>/imx-test-"version")
5 回复数
11,406 次查看
11,406 次查看
ssinfod
Thanks, I ordered and read that book already. It gives a good overview of yocto but I would like more examples on how to use the feature of the i.mx processor.
ssinfod
11,400 次查看
jimmychan
I think the Linux reference manual and the porting guide in the Yocto BSP documentation are useful for you.
11,400 次查看
ssinfod
Thanks these documents seems to contains a lot of usefull information.
One last question..
Can you explain to me one last thing. With Freescale MCU, I'm used to write the driver code myself. For example, I could set and get the UART registers (SCI0BD, SCI0DR), baud rate, data bits, etc..
With the Linux (yocto), who is writing the driver for the i.mx ? Is it the Freescale team or the Linux team ?
Where can I see the code for the i.mx peripheral drivers ? (Timer, UART, SPI, I2C) ?
In fact, I would like to see the i.mx peripheral driver code and also example on how to use it.
ssinfod
11,407 次查看
jimmychan
