EcoCAR2 - wall comments
3,300 次查看
Frias
Meeting place for the EcoCAR2 center stack developers.
标记 (2)
4 回复数
3,111 次查看
MichaelPattison
The following guide will help in the installation of QT.
Mike.
QTSetup_Eco2012.pdf
3,111 次查看
Frias
Hello All,
I apologize for the delay.
Please find attached the presentation delivered in the Winter workshop. 022012_EcoCariMX53_v1.pdf
3,111 次查看
MichaelPattison
Attached is a PDF of how to build a Linux image on an SD Card. I would recommend a 4GB or larger card, else you may run out of room.
FirstImageSetup_Eco2012.pdf
3,111 次查看
MichaelPattison
Setting up a terminal window to run with your i.mx board.
TerminalSetup_Eco2012
