EMMC problem
已解决
EMMC problem
跳至解决方案
1,784 次查看
wangcuixmwangcu
My imx6q board uses a 8GB emmc.
I want to chang to 64GB emmc.Is there a problem with that? Does the driver need to be modified?
标签 (1)
1 解答
1,682 次查看
Rita_Wang
It's OK to use the 64GB emmc on i.MX6Q. Here you need to use the 169 ball package in the schematic and PCB design. And about the dirvier you do not need to do modify.
Rita
在原帖中查看解决方案
1 回复
1,683 次查看
Rita_Wang
Rita
