imx6ul的唯一id
imx6ul的唯一id
王双
您好:
我们使用imx6ul的平台开发产品,想知道这个芯片是否有每块芯片都有唯一的id值,如果有的话,那要怎么从linux下获取到
BiyongSUN
You can check  the device unique ID
Rita_Wang
About the i.MX6UL you can see the part numbers for different chips. Details you can see the datasheet https://www.nxp.com/docs/en/data-sheet/IMX6ULCEC.pdf .
Rita
