Dual timer on generation on IMX8MM
1,368 次查看
Chandrasekhar1
Hi Team,
I'm new to driver development.
I have one custom driver which works with the API like "omap_dm_timer_request", "omap_dm_timer_set_source", "omap_dm_timer_set_prescaler", "omap_dm_timer_enable", "omap_dm_timer_get_irq" for timer generation.
Looking for the compatible API's for IMX8MM so that I can re-use the same driver.
So  could you please help to find the related API's for the above
1,352 次查看
Sanket_Parekh
I hope you are doing well.
Various timers available on i.MX Processors can be found in Table 5. Timers in i.MX Linux Reference Manual.
source code for the same can be found at below in kernel.
Thanks & Regards,
Sanket Parekh
