Driver for PF1550
Driver for PF1550
brinda-bhatt
Why do we have driver for PF1550 only in 4.19 version and removed for older versions?
Why is the driver not upstreamed?
brinda-bhatt
Hey Juan-Rodarte,
Did you manage to gather answers to my questions?
Juan-Rodarte
An apology, I couldn't find that information
brinda-bhatt
Thanks for your time Juan-Rodarte
brinda-bhatt
Thanks for the reply. I use PF1550 with imx6ull. I ported the driver and works fine. But for the safe side I would like to know before I actually use it for my product.
1) What was the reason to remove it from the newer version?
2) Why is it not upstreamed yet?
Brinda
Juan-Rodarte
It has been removed from the latest L5.4.24_2.1.0 release. However, if you are using pf1550 with i.MX6ULZ then you can still port/integrate those drivers in your BSP. I am reaching the BSP team to know the reason behind the removal of this driver, I will get back to you on this once I have an update.
