Driver Porting in Arm Cortex-M4
2,865 次查看
vinothkumars
Senior Contributor IV
Hi All,
I am working on IMX8QM-MEK with Android Automotive. I needs to port the new driver in Arm Cortex-M4 Core.
Will you give me some steps to port GSM driver in Arm Cortex-M4 core ?
Thanks & Regards,
Vinoth S,
Vinothkumar Sekar
2,726 次查看
Hi Vinoth
some gsm c programming examples can be found in
How to Interface GSM with LPC2148 ARM7 Development Board
How to interface Accelerometer, EEPROM, GPS and GSM with Cortex-M? - Embedded forum - System - Arm C...
2,726 次查看
vinothkumars
Hi Igor,
Will you please share the example code for GSM.
Thanks & Regards,
VinothS,
Vinothkumar Sekar
2,726 次查看
vinothkumars
Thank you Igor for quick reply.
I feel this input will help me.
VInothS,
Vinothkumar Sekar
