Does vpuenc_h264 uses hardware encoding? how?
sagarmane
I'm using i.MX8M Plus EVK board. Does vpuenc_h264 uses hardware encoding in below example of gstreamer?
#gst-launch-1.0 videotestsrc num-buffers=300 ! video/x-raw,width=1920,height=1080,format=YUY2 ! queue ! vpuenc_h264 ! filesink location=output.h264
joanxie
this uses HW(vpu) encoder
sagarmane
Hi @joanxie ,
Thanks for your response.
Yes this does work. My question was does vpuenc_h264 uses actual hardware available in board for encoding? or it is software encoding with gstreamer.
joanxie
joanxie
imx8mp should support this, you can try this, if you have any issue, pls tell me
