I'm using i.MX8M Plus EVK board. Does vpuenc_h264 uses hardware encoding in below example of gstreamer?
#gst-launch-1.0 videotestsrc num-buffers=300 ! video/x-raw,width=1920,height=1080,format=YUY2 ! queue ! vpuenc_h264 ! filesink location=output.h264
解決済! 解決策の投稿を見る。
Hi @joanxie ,
Thanks for your response.
Yes this does work. My question was does vpuenc_h264 uses actual hardware available in board for encoding? or it is software encoding with gstreamer.
this uses HW(vpu) encoder
imx8mp should support this, you can try this, if you have any issue, pls tell me
