pls refer to the source code as below:
试过了,不起作用,你们测试过?
默认驱动初始化过程中是关闭CSC功能的,
yes, this is tested version, another solution that you can use gstreamer, the command like:
Color Space Conversion (CSC)
"gst-launch-1.0 videotestsrc ! video/x-raw,format=NV12 ! imxvideoconvert_ipu ! video/xraw,
format=RGB16 ! ximagesink display=:0"
