Does it support Color space conversion in fsl-L4.9.11 kernel?
2,495 次查看
liangyan
_ipu_dp_set_csc_coefficients() /drivers/mxc/ipu_disp.c,  i want to change CSC using ioctl method, but  it has no effect.
if i change  dp_csc_param.mode = -1 into  dp_csc_param.mode = DP_COM_CONF_CSC_DEF_BOTH, it has effective
so it does not support change CSC, in timely
标签 (2)
4 回复数
2,436 次查看
joanxie
pls refer to the source code as below:
https://community.nxp.com/docs/DOC-101053
2,436 次查看
liangyan
试过了,不起作用,你们测试过?
2,436 次查看
liangyan
默认驱动初始化过程中是关闭CSC功能的,
2,436 次查看
joanxie
yes, this is tested version, another solution that you can use gstreamer, the command like:
Color Space Conversion (CSC)
"gst-launch-1.0 videotestsrc ! video/x-raw,format=NV12 ! imxvideoconvert_ipu ! video/xraw,
format=RGB16 ! ximagesink display=:0"
