Does i.MX8 Mini support NXP SoftISP?
sven_salzer
The standard key feature table of the i.MX8 processors does not mention OpenCL library for the i.MX 8M Mini. Can I use SW ISP Pipeline on i.MX8M Mini GPU Hardware? What is the difference to i.MX 8M that has different GPU libraries?
jamesbone
The i.Mx8M Mini it is using a different GPU from the i.MX8M,  GPU 3D changed from GC7000 lite to GCNanoUltra, Single Shader support, OpenCL/Open Vision/Vulkan is not natively supported.
Added 2D engine GC320, can use 2D for Color Space Conversion (CSC) and buffer transfers
constantinrazva
Hello [email protected]‌,
Unfortunately in this community we mostly handle MATLAB/Simulink topics for our toolboxes. I would suggest you post this question on the i.MX Processors  community to get the best answer on i.MX topics.
Kind regards,
Razvan.
