Does i.MX8 Mini support NXP SoftISP?
2,533 次查看
sven_salzer
The standard key feature table of the i.MX8 processors does not mention OpenCL library for the i.MX 8M Mini. Can I use SW ISP Pipeline on i.MX8M Mini GPU Hardware? What is the difference to i.MX 8M that has different GPU libraries?
标记 (1)
2,325 次查看
jamesbone
The i.Mx8M Mini it is using a different GPU from the i.MX8M,  GPU 3D changed from GC7000 lite to GCNanoUltra, Single Shader support, OpenCL/Open Vision/Vulkan is not natively supported.
Added 2D engine GC320, can use 2D for Color Space Conversion (CSC) and buffer transfers
2,325 次查看
constantinrazva
Hello [email protected]‌,
Unfortunately in this community we mostly handle MATLAB/Simulink topics for our toolboxes. I would suggest you post this question on the i.MX Processors  community to get the best answer on i.MX topics.
Kind regards,
Razvan.
