Does NXP provide imx6ul RNDIS drivers for windows?
yj_kim
Hi  everyone,
I'm reviewing RNDIS devices using imx6ul.
When I connect to Windows PC, it is recognized as an Unknown device but the driver is not installed.
Is there an RNDIS driver provided by NXP?
If there is no driver provided by NXP, which one should I use?
Thanks.
zackclarke
if you're still getting issues after installing rndis drive then joey explained step by step guide to installing rndis driver in your pc and after that, you must restart your computer and should be installed .net framework 3.5v in your computer and upgraded version on that. here the solution link was joey talking about rndis driver https://techocen.com/download-and-update-rndis-driver-for-windows-10/  and a direct download link of rndis driver. of http://download.windowsupdate.com/msdownload/update/driver/drvs/2012/12/20342322_4b9970e3174b23b5cb2...
Zack
Rita_Wang
Which version BSP are you using on your imx6ul?
hyejin
you mean Kernel version?
It's 4.14.98
Rita_Wang
