Does NXP provide imx6ul RNDIS drivers for windows?
4,090件の閲覧回数
yj_kim
Hi  everyone,
I'm reviewing RNDIS devices using imx6ul.
When I connect to Windows PC, it is recognized as an Unknown device but the driver is not installed.
Is there an RNDIS driver provided by NXP?
If there is no driver provided by NXP, which one should I use?
Thanks.
4 返答(返信)
3,800件の閲覧回数
zackclarke
if you're still getting issues after installing rndis drive then joey explained step by step guide to installing rndis driver in your pc and after that, you must restart your computer and should be installed .net framework 3.5v in your computer and upgraded version on that. here the solution link was joey talking about rndis driver https://techocen.com/download-and-update-rndis-driver-for-windows-10/  and a direct download link of rndis driver. of http://download.windowsupdate.com/msdownload/update/driver/drvs/2012/12/20342322_4b9970e3174b23b5cb2...
Zack
4,040件の閲覧回数
Rita_Wang
Which version BSP are you using on your imx6ul?
4,040件の閲覧回数
hyejin
you mean Kernel version?
It's 4.14.98
4,033件の閲覧回数
Rita_Wang
