Documentation flat cable connector ?
24,873 次查看
patrickklokowsk
Hello everyone,
i'm not able to find the right documentation for my type of board (png: picOfCon).
On
http://www.nxp.com/products/single-chip-modules/quick-start-board-for-scm-i.mx-6dq:QWKS-SCM-IMX6DQ
it is exactly my board illustrated. However the docu
http://www.nxp.com/products/single-chip-modules/quick-start-board-for-scm-i.mx-6dq:QWKS SCM-IMX6DQ?tab=Design_Tools_Tab
seems to refer to a version of the board with a different connector in that area where my flat cable connector is (png: wrong board).
On page 12 of the schematic pdf "SPF-28927-D" there is the pin configuration explained. But not for my kind of flat cable connector with 15 pins. On my board is a sticker with the following information "700-28927 REV X2 , SCH-28927 REV B3 , 04/14/16 35960-0093" if it helps. I would like to get the documentation of this board version (or just this connector).
Patrick
标签 (2)
5 回复数
24,690 次查看
patrickklokowsk
Seems to be the MIPI 15 Pin CSIx camera interface?!
May somebody confirm that with a source.
24,690 次查看
Rita_Wang
Hi Patrick,
Could you tell me if you  want to use the connector to realize some functions or something else?
Have a nice day
Rita
24,692 次查看
patrickklokowsk
that's exactly the place where the wrong (other board version) documentation can be found.
24,692 次查看
Rita_Wang
Hi Patrick,
I will do further confirming for you. And then give you reply.
Have a nice day
Rita
24,692 次查看
Rita_Wang
Hi Patrick,
You can get all the infomations about the your board here http://www.nxp.com/products/single-chip-modules/quick-start-board-for-scm-i.mx-6dq:QWKS-SCM-IMX6DQ . Here if you mainly need the infromantions on the flat cable connector?
Rita
