Diligent Pcan 5C (Ov5640 using 0x3d I2C address) on imx8
3,072件の閲覧回数
marekbelisko
I'm trying to test Dilligent Pcam 5C (using OV 5640 sensor). By just plugging it to by board camera is not recognized (cannot communicate over I2C).
I checked with i2cdetect and camera is not present on 0x3C but on 0x3D I2C address. When adjusted dts and recompile it I'm still getting:
[ 2.419131] ov5640_mipi 1-003d: No pin available
[ 2.423789] ov5640_mipi 1-003d: No sensor pwdn pin available
[ 2.429486] ov5640_mipi 1-003d: No sensor reset pin available
[ 2.435302] ov5640_mipi 1-003d: 1-003d supply DOVDD not found, using dummy regulator
[ 2.443128] ov5640_mipi 1-003d: 1-003d supply DVDD not found, using dummy regulator
[ 2.450856] ov5640_mipi 1-003d: 1-003d supply AVDD not found, using dummy regulator
[ 2.465884] ov5640_mipi 1-003d: Failed to update SCCB_ID to 0x7a
By reading code during probe camera switch I2C address to 0x78 but for my case seems it's not working. Anyone have similar experience and maybe some idea how to resolve this issue? Thanks.
タグ(1)
3,060件の閲覧回数
3 返答(返信)
3,049件の閲覧回数
marekbelisko
Hi Igor,
imx8mq and BSP I'm using dunfell yocto release (kernel 5.4.xx). On imx8mq evk camera chip ov5640 works fine (according dts -> I didn't try it by myself) I'm just curious if anyone else stumbled with problem that I2C address is not 0x3C but 0x3D and driver doesn't work out of the box. Thanks.
3,045件の閲覧回数
>mx8mq and BSP I'm using dunfell yocto release (kernel 5.4.xx)..
sorry nxp has not dunfell yocto release, probably you are using some third party linux release.
Please try nxp linux from source.codeaurora.org/external/imx/linux-imx repository
https://source.codeaurora.org/external/imx/linux-imx/tree/?h=lf-5.10.y
Documentation
https://www.nxp.com/design/software/embedded-software/i-mx-software/embedded-linux-for-i-mx-applicat...
3,061件の閲覧回数
Hi Marek
what processor and bsp used in the case. May be recommended to try nxp linux
Documentation
