Device Driver (I/O Expander)
2,221 次查看
oprata
Hello Folks!
I am trying to develop a device driver for a I/O expander. The device that I use for it is PCF8574T from NXP. And I am using the IMX8MMEVK board to do it.
I wrote a device driver that it works fine - look the attached pcf8574t.tar.gz. But now I would like to map each GpIO of pcf8574t on sysfs over /sys/class/gpio. Does anybody has a tip about how can I do it?
Thanks in advance.
标签 (1)
2 回复数
1,304 次查看
Transidico
hello,
do you still have the code you made? I have the same problem, it would be very helpful.
2,210 次查看
Zhiming_Liu
You can see this reply https://forums.balena.io/t/gpio-mapping-on-variscite-board/80718
Zhiming
