Detailed Signal Descriptions for IPU / CSI
3,201 次查看
KlausGuertler
 I intend connecting a camera (parallel interface) to IPUs CSI at iMX53. At almost all chapters in the reference manual there is a chapter "Detailed Signal Descriptions" according to the described peripheral. But not so at the IPU. Where can I find a list of the external signals related to the IPU/CSI and where is the detailed description of this signals?
Thanks in advance, Klaus
PS. Sorry to the group members they received this as a message. Initially I want to start a discussion and pressed the wrong button.
5 回复数
2,967 次查看
KlausGuertler
Hi Nitin, thanks for the hint. I concentrated on the reference manual and did not looked so deep into the data sheet.
I think this will help.
Best Regards
Klaus
2,967 次查看
NitinSonar
Hi Klaus,
You can refer to
"Table 57. Camera Input Signal Cross Reference, Format and Bits per Cycle"
of IMX53AEC: Datasheet document. The datasheet tells more about hardware and pin assignment details than RM.
Best Regards
Nitin Sonar
2,967 次查看
sidebranch
Klaus, you do not need this signal for BT or gated mode. I am not sure in which other modes this signal is needed, I hope Freescale can answer this here?
2,967 次查看
KlausGuertler
Thanks for the reply Leon. I'm a bit familiar with interfacing CMOS image sensors, but there is one signal which is unknown for me: CSI_DATA_EN. In general data from sensor is latched with the rising or falling edge of CSI_PIXCLK. What is the purpose of CSI_DATA_EN? In the data sheet there is nothing to found for this signal.
Klaus
2,967 次查看
sidebranch
Klaus, have you looked at the Datasheet? There are timing diagrams and electrical specs for the signals/pins.
If you have, let us know what info you are missing.
