Decoding HAB Event Data
4,268 次查看
jaapovertoom
How do I make sense of the following HAB Event Data? Where is this documented?
HAB Configuration: 0xf0 HAB
State: 0x66
--------- HAB Event 1
event data:
     0xdb
0x00 0x08 0x40 0x33 0x22 0x0a 0x00
--------- HAB Event 2
event data:
     0xdb
0x00 0x14 0x40 0x33 0x0c 0xa0 0x00
     0x00
0x00 0x00 0x00 0xf8 0x00 0x64 0x00
     0x00
0x00 0x00 0x20
--------- HAB Event 3
event data:
     0xdb
     0x00
0x00 0x00 0x00 0xf8 0x00 0x64 0x20
     0x00
0x00 0x00 0x01
--------- HAB Event 4
event data:
     0xdb
     0x00
0x00 0x00 0x00 0xf8 0x00 0x64 0x58
     0x00
0x00 0x00 0x04
--------- HAB Event 5
event data:
     0xdb
--------- HAB Event 6
event data:
     0xdb
--------- HAB Event 7
event data:
     0xdb
     0x00
0x00 0x00 0x00 0x77 0x80 0x04 0x2c
     0x00
0x00 0x00 0x20
--------- HAB Event 8
event data:
     0xdb
     0x00
0x00 0x00 0x00 0x30 0x00 0x00 0x00
     0x00
0x00 0x00 0x00
--------- HAB Event 9
event data:
     0xdb
     0x00
0x00 0x00 0x00 0x77 0x80 0x04 0x4c
     0x00
0x00 0x00 0x01
--------- HAB Event 10
event data:
     0xdb
     0x00
0x00 0x00 0x00 0x77 0x80 0x08 0x40
     0x00
0x00 0x00 0x04
--------- HAB Event 11
event data:
     0xdb
0x00 0x08 0x40 0x33 0x28 0xee 0x00
--------- HAB Event 12
event data:
     0xdb
--------- HAB Event 13
event data:
     0xdb
     0x00
0x00 0x00 0x00 0x77 0x80 0x04 0x00
     0x00
0x00 0x00 0x20
--------- HAB Event 14
event data:
     0xdb
     0x00
     0x00
0x00 0x01 0xa0
--------- HAB Event 15
event data:
     0xdb
     0x00
0x00 0x00 0x00 0x77 0x80 0x04 0x20
     0x00
0x00 0x00 0x01
--------- HAB Event 16
event data:
     0xdb
     0x00
0x00 0x00 0x00 0x77 0x80 0x05 0xe0
     0x00
0x00 0x00 0x04
标记 (1)
3,385 次查看
Yuri
Please look at my comments below.
1.
   According to the Appendix A (Interpreting HAB Event Data from Report_Event() API)
of the “HAB4_API.pdf” in the CST package, CAAM and SNVS engine failure takes place.
http://www.freescale.com/webapp/Download?colCode=IMX_CST_TOOL&appType=license&location=null&Parent_n...
Summary Page :i.MX 6 Series Software and Development Tool R|Freescale
event data:
    tag: 0xdb (HAB_TAG_EVT)
    sts: 0x33 (HAB_FAILURE)
    rsn: 0x28 (HAB_INV_CALL) Function called out of sequence
or
    rsn: 0x22 (HAB_INV_ADDRESS) Invalid address: access denied
or
    rsn: 0xc (HAB_INV_ASSERTION) Invalid assertion
If the reason of a HAB event is HAB_INV_ADDRESS (0x22)
[Invalid address: access denied] -  please check if initialization
via DCD table meet allowed addresses.
  Please take a look at Table 8-37 (Valid DCD Address Ranges) of the
i.MX6 DQ Reference Manual.
  For the case 0xc (HAB_INV_ASSERTION) – the HAB checks that all of the
following data have been authenticated (using their final locations):
- IVT ;
- DCD (if provided);
- Boot Data (initial byte if provided);
- Entry point (initial word).
  Each of the above data components not covered by a valid signature will cause HAB
to generate an event with reason HAB_INV_ASSERTION.
2.
  The SRK must be burned. Please look at section 18 (Burn the chip fuse to enable HAB boot)
of the “i.MX_6_Linux_High_Assurance_Boot_(HAB)_User's_Guide.pdf”.
Note, the SRK is only once burned.
Yuri
3,386 次查看
Yuri
1.
event data:
or
or
- IVT ;
2.
Yuri
