Debugging in FRDM i.MX 93 using J-Link
Shanmugapriya
Dear Team,
Greetings!
I want to run and debug an example code - "Hello world" in FRDM i.MX 93 Development board. I am using VS Code with the MCUXpresso extension. I am using a SEGGER J-Link probe with the SWD interface (SW_CLK, DIO and GND) and have modified the boot switches (1010) accordingly.
I am providing 3.3 V from P11 extension pins to the J-Link probe for Vref.
The connected device is correctly detected in both the Device Manager and VS Code.
However, when I attempt to start a debug session, it results in an error. I also verified the setup using Command Prompt, where I encountered the following error message: “DAP: Could not power-up system power domain.”
We kindly request your support in helping us move forward with resolving this issue. Please let me know if you require any additional details from our side.
I have attached reference screenshots.
Thanks in advance.
pengyong_zhang
Hi @Shanmugapriya
I am not familiar about wifi module, you can create another ticket talk about it. Thanks for your understanding.
B.R
pengyong_zhang
Hi @Shanmugapriya
Sorry, my mistake, i have contact it with my colleague, you need to connect it. And the voltage is 1.8V
B.R
Shanmugapriya
No problem—I was able to identify the pin that needs to be connected for Vref = 1.8 V after reviewing the schematic along with the board.
In the community post, it was mentioned that resistors R3017 and R3018 should be removed. I can find them in the schematic, but I’m unable to locate them on the FRDM board itself.
pengyong_zhang
Hi @Shanmugapriya
You can refer the attachment file find the location of  R3017 and R3018
B.R
Shanmugapriya
I have located the resistor on the board.
Now that I have removed R3017/R3018 and disconnected UART5 from the SoC, what happens to the Wi‑Fi module? What features will stop working?
pengyong_zhang
Hi @Shanmugapriya
B.R
pengyong_zhang
Hi @Shanmugapriya
Does not need the Vref pin. Only SWCLK and SWDIO is fine.
B.R
Shanmugapriya
Could you please check this https://community.nxp.com/t5/FRDM-Training-Hub/How-to-use-J-link-on-FRDM-IMX93/ta-p/2122902
If Vref is not required, this community post link misleads
pengyong_zhang
hI @Shanmugapriya
i.MX93 FRDM board use Serial wire debug (SWD) mode. please use SWD mode run the M core debug.
SWCLK-> SWCLK Jlink
SWDIO-> SWDIO Jlink
GND  -> GND Jlink
B.R
Shanmugapriya
I connected the wiring using the same configuration and performed the M‑core debugging, but I still encountered the error:  "DAP: Could not power-up system power domain."
First, is Vref required in this setup?
If it is required, what voltage should be supplied to the Vref pin?
pengyong_zhang
Hi @Shanmugapriya
You can debug the m-core of the imx93 according to the process in the attachment file.
Please take a full board connection picture. Include your board J-Link PC
B.R
Shanmugapriya
With reference to the provided manual, I have successfully imported the SDK and built the sample project. However, I am currently facing an issue at the debug and run stage. The reference image in the manual illustrating the debug probe connection is for a different board and does not match the FRDM i.MX 93 hardware.
Additionally, the FRDM i.MX 93 board does not include a standard 10-pin debug connector; instead, it exposes only three SWD pins. Because of this, I am unable to proceed with debugging as described in the manual. I have attached images showing the board connections to the Segger J-Link for reference.
I would like to clarify whether the Vref for the SWD interface on this board is 3.3 V or 1.8 V.
%3CLINGO-SUB%20id%3D%22lingo-sub-2297138%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EDebugging%20in%20FRDM%20i.MX%2093%20using%20J-Link%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2297138%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20Team%2C%3C%2FP%3E%3CP%3EGreetings!%3C%2FP%3E%3CP%3EI%20want%20to%20run%20and%20debug%20an%20example%20code%20-%20%22Hello%20world%22%20in%20FRDM%20i.MX%2093%20Development%20board.%20I%20am%20using%20VS%20Code%20with%20the%20MCUXpresso%20extension.%26nbsp%3B%3CSPAN%3EI%20am%20using%20a%20SEGGER%20J-Link%20probe%20with%20the%20SWD%20interface%20(SW_CLK%2C%20DIO%20and%20GND)%20and%20have%20modified%20the%20boot%20switches%20(1010)%20accordingly.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EI%20am%20providing%203.3%20V%20from%20P11%20extension%20pins%20to%20the%20J-Link%20probe%20for%20Vref.%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EThe%20connected%20device%20is%20correctly%20detected%20in%20both%20the%20Device%20Manager%20and%20VS%20Code.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EHowever%2C%20when%20I%20attempt%20to%20start%20a%20debug%20session%2C%20it%20results%20in%20an%20error.%20I%20also%20verified%20the%20setup%20using%20Command%20Prompt%2C%20where%20I%20encountered%20the%20following%20error%20message%3A%26nbsp%3B%E2%80%9CDAP%3A%20Could%20not%20power-up%20system%20power%20domain.%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EWe%20kindly%20request%20your%20support%20in%20helping%20us%20move%20forward%20with%20resolving%20this%20issue.%20Please%20let%20me%20know%20if%20you%20require%20any%20additional%20details%20from%20our%20side.%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EI%20have%20attached%20reference%20screenshots.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EThanks%20in%20advance.%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2297959%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Debugging%20in%20FRDM%20i.MX%2093%20using%20J-Link%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2297959%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258983%22%20target%3D%22_blank%22%3E%40Shanmugapriya%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3ESorry%2C%20my%20mistake%2C%20i%20have%20contact%20it%20with%20my%20colleague%2C%20you%20need%20to%20connect%20it.%20And%20the%20voltage%20is%201.8V%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2297851%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Debugging%20in%20FRDM%20i.MX%2093%20using%20J-Link%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2297851%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ECould%20you%20please%20check%20this%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FFRDM-Training-Hub%2FHow-to-use-J-link-on-FRDM-IMX93%2Fta-p%2F2122902%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FFRDM-Training-Hub%2FHow-to-use-J-link-on-FRDM-IMX93%2Fta-p%2F2122902%3C%2FA%3E%3C%2FP%3E%3CP%3EIf%20Vref%20is%20not%20required%2C%20this%20community%20post%20link%20misleads%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2297842%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Debugging%20in%20FRDM%20i.MX%2093%20using%20J-Link%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2297842%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258983%22%20target%3D%22_blank%22%3E%40Shanmugapriya%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EDoes%20not%20need%20the%20Vref%20pin.%20Only%20SWCLK%20and%20SWDIO%20is%20fine.%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2297828%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Debugging%20in%20FRDM%20i.MX%2093%20using%20J-Link%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2297828%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3EI%20connected%20the%20wiring%20using%20the%20same%20configuration%20and%20performed%20the%20M%E2%80%91core%20debugging%2C%20but%20I%20still%20encountered%20the%20error%3A%26nbsp%3B%20%22%3CSPAN%3EDAP%3A%20Could%20not%20power-up%20system%20power%20domain.%22%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3EFirst%2C%20is%20%3CSTRONG%3EVref%3C%2FSTRONG%3E%20required%20in%20this%20setup%3F%3CBR%20%2F%3EIf%20it%20is%20required%2C%20what%20voltage%20should%20be%20supplied%20to%20the%20%3CSTRONG%3EVref%3C%2FSTRONG%3E%20pin%3F%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2297738%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Debugging%20in%20FRDM%20i.MX%2093%20using%20J-Link%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2297738%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EhI%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258983%22%20target%3D%22_blank%22%3E%40Shanmugapriya%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3Ei.MX93%20FRDM%20board%20use%26nbsp%3BSerial%20wire%20debug%20(SWD)%20mode.%20please%20use%20SWD%20mode%20run%20the%20M%20core%20debug.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pengyong_zhang_0-1769050378496.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pengyong_zhang_0-1769050378496.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pengyong_zhang_0-1769050378496.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pengyong_zhang_0-1769050378496.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pengyong_zhang_0-1769050378496.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pengyong_zhang_0-1769050378496.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F373759iB689027E337A4C07%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22pengyong_zhang_0-1769050378496.png%22%20alt%3D%22pengyong_zhang_0-1769050378496.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%3CCODE%3ESWCLK%3C%2FCODE%3E%3C%2FSTRONG%3E%3CSPAN%3E-%26gt%3B%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3E%3CCODE%3ESWCLK%20Jlink%3C%2FCODE%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%3CCODE%3ESWDIO%3C%2FCODE%3E%3CSPAN%3E-%26gt%3B%26nbsp%3B%3C%2FSPAN%3E%3CCODE%3ESWDIO%20Jlink%3C%2FCODE%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%3CCODE%3EGND%26nbsp%3B%20%3C%2FCODE%3E%3CSPAN%3E-%26gt%3B%26nbsp%3B%3C%2FSPAN%3E%3CCODE%3EGND%20Jlink%3C%2FCODE%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2297309%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Debugging%20in%20FRDM%20i.MX%2093%20using%20J-Link%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2297309%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EWith%20reference%20to%20the%20provided%20manual%2C%20I%20have%20successfully%20imported%20the%20SDK%20and%20built%20the%20sample%20project.%20However%2C%20I%20am%20currently%20facing%20an%20issue%20at%20the%20debug%20and%20run%20stage.%20The%20reference%20image%20in%20the%20manual%20illustrating%20the%20debug%20probe%20connection%20is%20for%20a%20different%20board%20and%20does%20not%20match%20the%20FRDM%20i.MX%2093%20hardware.%3C%2FP%3E%3CP%3EAdditionally%2C%20the%20FRDM%20i.MX%2093%20board%20does%20not%20include%20a%20standard%2010-pin%20debug%20connector%3B%20instead%2C%20it%20exposes%20only%20three%20SWD%20pins.%20Because%20of%20this%2C%20I%20am%20unable%20to%20proceed%20with%20debugging%20as%20described%20in%20the%20manual.%20I%20have%20attached%20images%20showing%20the%20board%20connections%20to%20the%20Segger%20J-Link%20for%20reference.%3C%2FP%3E%3CP%3EI%20would%20like%20to%20clarify%20whether%20the%20Vref%20for%20the%20SWD%20interface%20on%20this%20board%20is%203.3%20V%20or%201.8%20V.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22shared%20image%20(14).jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22shared%20image%20(14).jpg%22%20style%3D%22width%3A%20180px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22shared%20image%20(14).jpg%22%20style%3D%22width%3A%20180px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22shared%20image%20(14).jpg%22%20style%3D%22width%3A%20180px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22shared%20image%20(14).jpg%22%20style%3D%22width%3A%20180px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22shared%20image%20(14).jpg%22%20style%3D%22width%3A%20180px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F373670iF8E7945CC78F1C99%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22shared%20image%20(14).jpg%22%20alt%3D%22shared%20image%20(14).jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22shared%20image%20(15).jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22shared%20image%20(15).jpg%22%20style%3D%22width%3A%20180px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22shared%20image%20(15).jpg%22%20style%3D%22width%3A%20180px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22shared%20image%20(15).jpg%22%20style%3D%22width%3A%20180px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22shared%20image%20(15).jpg%22%20style%3D%22width%3A%20180px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22shared%20image%20(15).jpg%22%20style%3D%22width%3A%20180px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F373671iC1B259A0CC873342%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22shared%20image%20(15).jpg%22%20alt%3D%22shared%20image%20(15).jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22shared%20image%20(13).jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22shared%20image%20(13).jpg%22%20style%3D%22width%3A%20180px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22shared%20image%20(13).jpg%22%20style%3D%22width%3A%20180px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22shared%20image%20(13).jpg%22%20style%3D%22width%3A%20180px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22shared%20image%20(13).jpg%22%20style%3D%22width%3A%20180px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22shared%20image%20(13).jpg%22%20style%3D%22width%3A%20180px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F373672iF720A4D88246E90D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22shared%20image%20(13).jpg%22%20alt%3D%22shared%20image%20(13).jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E2%80%83%E2%80%83%E2%80%83%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2297246%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Debugging%20in%20FRDM%20i.MX%2093%20using%20J-Link%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2297246%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258983%22%20target%3D%22_blank%22%3E%40Shanmugapriya%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EYou%20can%20debug%20the%20m-core%20of%20the%20imx93%20according%20to%20the%20process%20in%20the%20attachment%20file.%3C%2FP%3E%0A%3CP%3EPlease%20take%20a%20full%20board%20connection%20picture.%20Include%20your%20board%20J-Link%20PC%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2298124%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Debugging%20in%20FRDM%20i.MX%2093%20using%20J-Link%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2298124%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3ENo%20problem%E2%80%94I%20was%20able%20to%20identify%20the%20pin%20that%20needs%20to%20be%20connected%20for%20Vref%20%3D%201.8%20V%20after%20reviewing%20the%20schematic%20along%20with%20the%20board.%3C%2FP%3E%3CP%3EIn%20the%20community%20post%2C%20it%20was%20mentioned%20that%20resistors%20%3CSTRONG%3ER3017%3C%2FSTRONG%3E%20and%20%3CSTRONG%3ER3018%3C%2FSTRONG%3E%20should%20be%20removed.%20I%20can%20find%20them%20in%20the%20schematic%2C%20but%20I%E2%80%99m%20unable%20to%20locate%20them%20on%20the%20FRDM%20board%20itself.%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2298216%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Debugging%20in%20FRDM%20i.MX%2093%20using%20J-Link%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2298216%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20have%20located%20the%20resistor%20on%20the%20board.%3C%2FP%3E%3CDIV%3ENow%20that%20I%20have%20removed%20R3017%2FR3018%20and%20disconnected%20UART5%20from%20the%20SoC%2C%20what%20happens%20to%20the%20Wi%E2%80%91Fi%20module%3F%20What%20features%20will%20stop%20working%3F%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2300074%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Debugging%20in%20FRDM%20i.MX%2093%20using%20J-Link%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2300074%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258983%22%20target%3D%22_blank%22%3E%40Shanmugapriya%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EI%20am%20not%20familiar%20about%20wifi%20module%2C%20you%20can%20create%20another%20ticket%20talk%20about%20it.%20Thanks%20for%20your%20understanding.%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2300073%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Debugging%20in%20FRDM%20i.MX%2093%20using%20J-Link%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2300073%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258983%22%20target%3D%22_blank%22%3E%40Shanmugapriya%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EYou%20can%20refer%20the%20attachment%20file%20find%20the%20location%20of%26nbsp%3B%20R3017%20and%20R3018%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E
