Debugging Linux Kernel on IMx6SoloX through Lauterbach Debugger
niranjanbc
I am trying to debug the Linux Kernel running on IMX6SoloX with Lauterbach, but my Linux never boots up.
attached is the script file, i am using to initialize the board and load Kernel, DTB & Ram Disk. I am not sure weather i am loading those at right address, where and how do i find those values from.
From Script file, i have some comments below. can someone correct me if i am wrong. suggest where i can find the right values.
Niranjan
Original Attachment has been moved to: imx6solox_linux_ph_att.cmm.zip
Yuri
 Please create request in order to send You some Linux (JTAG based) debug considerations.
Support|NXP
Yuri
niranjanbc
Thank Yuri
will do
