DSI D-Phy Configuration
1,417 次查看
guido_gunther
Somewhat related to imx8m GPRs for MIPI DSI the imx8 RM has `MIPI_DSI_HOST_FSL_IP1_DPHY_` registers  in "MIPI DSI Host IP1 DPHY INTFC Memory Map/Register Definition" where the manual says
"Detailed information about this parameter programming is available in the MIPI-DSI DPHY section."
but there is no further information about these values in the d-phy section. Can you provide these please?
标记 (3)
0 回复数
