hi Freescale:
our board design is base on SDB board,the OS is Android4.4.2.
my problem is in DDR3 Configration. our HW engineers
relayout the board for DDR3, the freeescale "Hareware
development guide" had said that "Swapping data lines"(please
check attachment_1). i found the SDB board has swap the data
lines in freescale board. but our HW engineers swap more data
lines. I want to konw the "flash_header.S" or other file need to
change in uboot??
how to change the software code to adjust the "If byte lane swapping was done, target DDR IC register read value must be
transposed according to the data line swapping"
the DDR3 is very important for our board, please give me some
suggest, thank you!
our board DDR3 chip is same as SDB. the data line different please check attachment_2/attachment_3/attachment_4/attachment_5
