Custom HDMI Resolution on i.MX 8MP
1,549件の閲覧回数
masalcp
Hello everyone,
I want to display 3840x726@60 and 3840x1080@60 via HDMI, and it would be helpful if you could add the necessary HDMI PLL configuration to samsung_phy_pll_cfg[] in "drivers/phy/freescale/phy-fsl-samsung-hdmi.c".
Thank you.
1,233件の閲覧回数
masalcp
I referred to samsung-hdmi-phy-pll-calculator and the phy-fsl-samsung-hdmi.c file from lf-6.22.y, and added a new entry to the static const struct phy_config phy_pll_cfg[] array accordingly.
As a result, the display output is now working correctly.
4 返答(返信)
1,487件の閲覧回数
Bio_TICFSL
To achieve 3840x726@60 and 3840x1080@60 via HDMI, rhe exact HDMI PLL configuration for the samsung_phy driver depends on your specific driver version, but you will need to adjust the Pixel Clock (PCLK), Dot Clock, or TMDS (Transition Minimized Differential Signaling) Clock to match the required data rate for the selected resolution and refresh rate.
1. Determine the Required Bandwidth
First, calculate the total pixel rate (or dot clock) for each resolution:
  • 3840x726@60Hz: (3840 * 726 * 60) / 1,000,000 = ~167.96 MHz
  • 3840x1080@60Hz: (3840 * 1080 * 60) / 1,000,000 = ~248.83 MHz
2. Find the samsung_phy_ Driver Configuration
  • Locate the samsung_phy_ driver source code:
    You will need to find the relevant driver files (e.g., drivers/phy/samsung/ in the Linux kernel) to see how clocking and PLLs are controlled.
  • Examine existing PLL configurations:
    Look for functions related to clock generation or PLL setup within the driver.
3. Adjust the PLL Configuration  and set the dtb
  • You will need to find the appropriate registers within the samsung_phy_ driver that control the PLL (Phase-Locked Loop) or Clock Controller.
  • Set the PLL to generate the correct PCLK: based on your desired resolution
1,440件の閲覧回数
masalcp
I'm working on a project using the Yocto Scarthgap release, and I'm trying to enable a custom HDMI resolution of 3840x1080 @ 60Hz.
The required pixel clock for this mode is 266.64 MHz. To support this, I have added the following entry to the samsung_phy_pll_cfg[] array in the drivers/phy/freescale/phy-fsl-samsung-hdmi.c file:
C
    // 3840x1080@60Hz (266.64 MHz)
    266640000, {
        0x00, 0xD1, 0x6B, 0x15, 0x89, 0x05, 0x88, 0x45,
        0x4F, 0x30, 0x33, 0x65, 0x30, 0xB8, 0x24, 0x80,
        0x6C, 0xF2, 0x67, 0x00, 0x10, 0x81, 0x30, 0x32,
        0x60, 0x8F, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00,
        0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
        0x00, 0xE0, 0x83, 0x0F, 0x3E, 0xF8, 0x00, 0x00,
However, after applying this change and booting the system, I get no output on the display (a black screen). I suspect that these PHY PLL register values are incorrect for my hardware.
My main question is: Is there a PLL configuration tool available that can generate the correct register settings for the Samsung HDMI PHY for a given clock rate?
Please note that I cannot simply use the latest phy-fsl-samsung-hdmi.c driver from the mainline kernel, as it causes build errors within my current Yocto Scarthgap environment.
Any advice or suggestions would be greatly appreciated.
Thank you.
1,422件の閲覧回数
Bio_TICFSL
The PLL is crucial for generating the necessary clock frequencies for the HDMI serializer, which serializes parallel data into a high-speed serial stream for HDMI output. In phy-fsl-samsung-hdmi.c, the PLL is configured with parameters (often stored in a Look-Up Table or LUT) to match the specific pixel clock required by the display, as seen in discussions about adding new modes and adjusting PLL settings for different resolutions like
2560×14402560 cross 1440
2560×1440
and
1920×12001920 cross 1200
1920×1200
How the PLL is used:
  • Clock generation:
    The PLL takes reference clocks (like APB and reference clocks) and generates the precise clock frequencies needed for the HDMI serializer to operate correctly.
  • Configuration for different modes:
    To support various video modes, the driver needs to configure the PLL with specific parameters for each supported pixel clock frequency. This is often handled by a Look-Up Table (LUT) containing the necessary settings.
  • Driver and hardware interaction:
    The phy-fsl-samsung-hdmi.c file contains the code that configures the hardware PLL, which is a part of the Samsung HDMI PHY, to meet the required timing and clocking specifications for the display to function.
  • Driver development:
    There are ongoing efforts to extend the driver's capabilities by adding support for more modes and fine-tuning the PLL settings, as shown by recent patches adding new LUT entries and adjusting PLL lock detection mechanisms
1,234件の閲覧回数
masalcp
%3CLINGO-SUB%20id%3D%22lingo-sub-2179667%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX%208MP%E3%81%AE%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0HDMI%E8%A7%A3%E5%83%8F%E5%BA%A6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2179667%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%81%BF%E3%82%93%E3%81%AA%E3%80%81%3CBR%20%2F%3E%20HDMI%E7%B5%8C%E7%94%B1%E3%81%A73840x726%4060%E3%81%A83840x1080%4060%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%9F%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%80%8C%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%2Fphy%2Ffreescale%2Fphy-fsl-samsung-hdmi.c%E3%80%8D%E3%81%AEsamsung_phy_pll_cfg%5B%5D%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AAHDMI%20PLL%E8%A8%AD%E5%AE%9A%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8B%E3%81%A8%E5%8A%A9%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2191072%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Custom%20HDMI%20Resolution%20on%20i.MX%208MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2191072%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Elf-6.22.y%20%E3%81%AE%3CA%20href%3D%22https%3A%2F%2Fcodeberg.org%2Ffschrempf%2Fsamsung-hdmi-phy-pll-calculator%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Esamsung-hdmi-phy-pll-%E3%82%AB%E3%83%AA%E3%82%AD%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%3C%2FA%3E%E3%81%A8%20phy-fsl-samsung-hdmi.c%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%20static%20const%20struct%20phy_config%20phy_pll_cfg%5B%5D%20%E9%85%8D%E5%88%97%E3%81%AB%E6%96%B0%E3%81%97%E3%81%84%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%9D%E3%81%AE%E7%B5%90%E6%9E%9C%E3%80%81%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E5%87%BA%E5%8A%9B%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2183952%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Custom%20HDMI%20Resolution%20on%20i.MX%208MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2183952%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CDIV%20class%3D%22rPeykc%22%20data-hveid%3D%22CAQQAQ%22%20data-ved%3D%222ahUKEwie_7vV85mQAxX6nu4BHUnYKH4Qo_EKegQIBBAB%22%3E%3CSPAN%20data-huuid%3D%225492386072387260512%22%3EPLL%E3%81%AF%E3%80%81HDMI%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%A9%E3%82%A4%E3%82%B6%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%91%A8%E6%B3%A2%E6%95%B0%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%B8%8D%E5%8F%AF%E6%AC%A0%E3%81%A7%E3%81%99%E3%80%82HDMI%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%A9%E3%82%A4%E3%82%B6%E3%81%AF%E3%80%81%E3%83%91%E3%83%A9%E3%83%AC%E3%83%AB%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E9%AB%98%E9%80%9F%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%97%E3%81%A6HDMI%E5%87%BA%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82phy%3C%2FSPAN%3E%20%3CSPAN%20data-huuid%3D%225492386072387261635%22%3E%3CCODE%20class%3D%22mv6bHd%22%3Ephy-fsl-samsung-hdmi.c%3C%2FCODE%3E%E3%81%A7%E3%81%AF%E3%80%81PLL%E3%81%AF%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E7%89%B9%E5%AE%9A%E3%81%AE%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AB%E5%90%88%E3%82%8F%E3%81%9B%E3%81%A6%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%EF%BC%88%E5%A4%9A%E3%81%8F%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%83%AB%E3%83%83%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%EF%BC%88LUT%EF%BC%89%E3%81%AB%E6%A0%BC%E7%B4%8D%EF%BC%89%E3%81%A7%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E8%BF%BD%E5%8A%A0%E3%82%84%E3%80%81%E6%A7%98%E3%80%85%E3%81%AA%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%81%AB%E5%90%88%E3%82%8F%E3%81%9B%E3%81%A6PLL%E8%A8%AD%E5%AE%9A%E3%82%92%E8%AA%BF%E6%95%B4%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%AD%B0%E8%AB%96%E3%81%A7%E8%A6%8B%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%0A%3CDIV%20class%3D%22CM8kHf%20j86kh%22%20data-hveid%3D%22CAkQAQ%22%3E%0A%3CDIV%20data-expression%3D%222560%20%5Ctimes%201440%22%3E%0A%3CDIV%20style%3D%22position%3A%20relative%3B%20direction%3A%20ltr%3B%20display%3A%20inline-flex%3B%20max-width%3A%20100%25%3B%20overflow-x%3A%20auto%3B%20vertical-align%3A%20-0.25em%3B%22%20tabindex%3D%22-1%22%20data-xpm-copy-root%3D%22%22%3E%0A%3CDIV%20id%3D%22tinyMceEditorBio_TICFSL_0%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CBR%20%2F%3E%0A%3CDIV%20style%3D%22display%3A%20block%3B%20inset%3A%200%3B%20opacity%3A%200.001%3B%20overflow%3A%20hidden%3B%20position%3A%20absolute%3B%20user-select%3A%20none%3B%22%3E2560%C3%9714402560%E3%82%AF%E3%83%AD%E3%82%B91440%3C%2FDIV%3E%0A2560%C3%971440%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CSPAN%20data-huuid%3D%225492386072387261635%22%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%20%3C%2FSPAN%3E%0A%3CDIV%20class%3D%22CM8kHf%20j86kh%22%20data-hveid%3D%22CAkQAg%22%3E%0A%3CDIV%20data-expression%3D%221920%20%5Ctimes%201200%22%3E%0A%3CDIV%20style%3D%22position%3A%20relative%3B%20direction%3A%20ltr%3B%20display%3A%20inline-flex%3B%20max-width%3A%20100%25%3B%20overflow-x%3A%20auto%3B%20vertical-align%3A%20-0.25em%3B%22%20tabindex%3D%22-1%22%20data-xpm-copy-root%3D%22%22%3E%0A%3CDIV%20id%3D%22tinyMceEditorBio_TICFSL_1%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CBR%20%2F%3E%0A%3CDIV%20style%3D%22display%3A%20block%3B%20inset%3A%200%3B%20opacity%3A%200.001%3B%20overflow%3A%20hidden%3B%20position%3A%20absolute%3B%20user-select%3A%20none%3B%22%3E1920%C3%9712001920%E3%82%AF%E3%83%AD%E3%82%B91200%3C%2FDIV%3E%0A1920%C3%971200%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CSPAN%20data-huuid%3D%225492386072387261635%22%3E%3CSPAN%20class%3D%22M5tQyf%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20class%3D%22pjBG2e%22%20data-cid%3D%229716b697-5402-4600-acb7-3eea484aa7b7%22%3E%3CSPAN%20class%3D%22UV3uM%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CDIV%20class%3D%22NPrrbc%22%20data-cid%3D%229716b697-5402-4600-acb7-3eea484aa7b7%22%20data-uuids%3D%225492386072387263485%2C5492386072387260512%2C5492386072387261635%22%3E%0A%3CDIV%20class%3D%22BMebGe%20btku5b%20LwdV0e%20FR7ZSc%20OJeuxf%22%20tabindex%3D%220%22%20role%3D%22button%22%20aria-label%3D%22Ver%20v%C3%ADnculos%20relacionados%22%20data-hveid%3D%22CAkQAw%22%20data-ved%3D%222ahUKEwie_7vV85mQAxX6nu4BHUnYKH4Q3fYKegQICRAD%22%3E%0A%3CDIV%20class%3D%22niO4u%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20id%3D%229716b697-5402-4600-acb7-3eea484aa7b7%22%20style%3D%22display%3A%20none%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20style%3D%22display%3A%20none%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20style%3D%22display%3A%20none%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20style%3D%22display%3A%20none%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20style%3D%22display%3A%20none%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20style%3D%22display%3A%20none%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20id%3D%22_ZyDpaN6vDfq9ur8PybCj8Qc_33%22%20style%3D%22display%3A%20none%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CDIV%20class%3D%22rPeykc%20uP58nb%20rWIipd%22%20data-hveid%3D%22CBIQAQ%22%20data-ved%3D%222ahUKEwie_7vV85mQAxX6nu4BHUnYKH4Qo_EKegQIEhAB%22%3E%3CSPAN%20data-huuid%3D%226644578505966019247%22%3EPLL%20%E3%81%AE%E4%BD%BF%E7%94%A8%E6%96%B9%E6%B3%95%3A%20%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CUL%20data-hveid%3D%22CCcQAQ%22%20data-ved%3D%222ahUKEwie_7vV85mQAxX6nu4BHUnYKH4Qm_YKegQIJxAB%22%3E%0A%3CLI%3E%0A%3CDIV%20class%3D%22zMgcWd%20dSKvsb%22%20data-il%3D%22%22%3E%0A%3CDIV%20data-crb-p%3D%22%22%3E%0A%3CDIV%20class%3D%22xFTqob%22%3E%0A%3CDIV%20class%3D%22Gur8Ad%22%20style%3D%22display%3A%20inline%3B%22%3E%3CSPAN%20data-huuid%3D%226644578505966019104%22%3E%3CSTRONG%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E7%94%9F%E6%88%90%3A%3C%2FSTRONG%3E%20%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22vM0jzc%22%20style%3D%22display%3A%20inline%3B%22%3E%3CSPAN%20data-huuid%3D%226644578505966021787%22%3EPLL%20%E3%81%AF%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20(APB%20%E3%82%84%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AA%E3%81%A9)%20%E3%82%92%E5%8F%97%E3%81%91%E5%8F%96%E3%82%8A%E3%80%81HDMI%20%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%A9%E3%82%A4%E3%82%B6%E3%83%BC%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E6%AD%A3%E7%A2%BA%E3%81%AA%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%91%A8%E6%B3%A2%E6%95%B0%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20class%3D%22pjBG2e%22%20data-cid%3D%22f980b1f7-7985-4d1c-ae2d-0759584c0028%22%3E%3CSPAN%20class%3D%22UV3uM%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CDIV%20class%3D%22NPrrbc%22%20data-cid%3D%22f980b1f7-7985-4d1c-ae2d-0759584c0028%22%20data-uuids%3D%226644578505966019104%2C6644578505966021787%22%3E%0A%3CDIV%20class%3D%22BMebGe%20btku5b%20LwdV0e%20FR7ZSc%20OJeuxf%22%20tabindex%3D%220%22%20role%3D%22button%22%20aria-label%3D%22Ver%20v%C3%ADnculos%20relacionados%22%20data-hveid%3D%22CBwQAQ%22%20data-ved%3D%222ahUKEwie_7vV85mQAxX6nu4BHUnYKH4Q3fYKegQIHBAB%22%3E%0A%3CDIV%20class%3D%22niO4u%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20id%3D%22f980b1f7-7985-4d1c-ae2d-0759584c0028%22%20style%3D%22display%3A%20none%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20style%3D%22display%3A%20none%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CDIV%20class%3D%22zMgcWd%20dSKvsb%22%20data-il%3D%22%22%3E%0A%3CDIV%20data-crb-p%3D%22%22%3E%0A%3CDIV%20class%3D%22xFTqob%22%3E%0A%3CDIV%20class%3D%22Gur8Ad%22%20style%3D%22display%3A%20inline%3B%22%3E%3CSPAN%20data-huuid%3D%226644578505966018961%22%3E%3CSTRONG%3E%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E6%A7%8B%E6%88%90%3A%3C%2FSTRONG%3E%20%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22vM0jzc%22%20style%3D%22display%3A%20inline%3B%22%3E%3CSPAN%20data-huuid%3D%226644578505966021644%22%3E%E6%A7%98%E3%80%85%E3%81%AA%E3%83%93%E3%83%87%E3%82%AA%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%82%8B%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%94%E3%81%A8%E3%81%AB%E7%89%B9%E5%AE%9A%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6PLL%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20data-huuid%3D%226644578505966020231%22%3E%E3%81%93%E3%82%8C%E3%81%AF%E9%80%9A%E5%B8%B8%E3%80%81%E5%BF%85%E8%A6%81%E3%81%AA%E8%A8%AD%E5%AE%9A%E3%82%92%E5%90%AB%E3%82%80%E3%83%AB%E3%83%83%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%EF%BC%88LUT%EF%BC%89%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%87%A6%E7%90%86%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20class%3D%22pjBG2e%22%20data-cid%3D%224785b785-9fae-445e-bdef-4acaba7cccd2%22%3E%3CSPAN%20class%3D%22UV3uM%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CDIV%20class%3D%22NPrrbc%22%20data-cid%3D%224785b785-9fae-445e-bdef-4acaba7cccd2%22%20data-uuids%3D%226644578505966018961%2C6644578505966021644%2C6644578505966020231%22%3E%0A%3CDIV%20class%3D%22BMebGe%20btku5b%20LwdV0e%20FR7ZSc%20OJeuxf%22%20tabindex%3D%220%22%20role%3D%22button%22%20aria-label%3D%22Ver%20v%C3%ADnculos%20relacionados%22%20data-hveid%3D%22CCEQAQ%22%20data-ved%3D%222ahUKEwie_7vV85mQAxX6nu4BHUnYKH4Q3fYKegQIIRAB%22%3E%0A%3CDIV%20class%3D%22niO4u%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20id%3D%224785b785-9fae-445e-bdef-4acaba7cccd2%22%20style%3D%22display%3A%20none%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20style%3D%22display%3A%20none%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CDIV%20class%3D%22zMgcWd%20dSKvsb%22%20data-il%3D%22%22%3E%0A%3CDIV%20data-crb-p%3D%22%22%3E%0A%3CDIV%20class%3D%22xFTqob%22%3E%0A%3CDIV%20class%3D%22Gur8Ad%22%20style%3D%22display%3A%20inline%3B%22%3E%3CSPAN%20data-huuid%3D%226644578505966021501%22%3E%3CSTRONG%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%A8%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E7%9B%B8%E4%BA%92%E4%BD%9C%E7%94%A8%3A%3C%2FSTRONG%3E%20%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22vM0jzc%22%20style%3D%22display%3A%20inline%3B%22%3E%3CSPAN%20data-huuid%3D%226644578505966020088%22%3E%3CCODE%20class%3D%22mv6bHd%22%3Ephy-fsl-samsung-hdmi.c%3C%2FCODE%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%81%AF%E3%80%81%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%A8%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E4%BB%95%E6%A7%98%E3%82%92%E6%BA%80%E3%81%9F%E3%81%99%E3%82%88%E3%81%86%E3%81%AB%E3%80%81Samsung%20HDMI%20PHY%20%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%A7%E3%81%82%E3%82%8B%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%20PLL%20%E3%82%92%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20class%3D%22pjBG2e%22%20data-cid%3D%22aed9105b-4628-4749-8f80-e8d7c343bd47%22%3E%3CSPAN%20class%3D%22UV3uM%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CDIV%20class%3D%22NPrrbc%22%20data-cid%3D%22aed9105b-4628-4749-8f80-e8d7c343bd47%22%20data-uuids%3D%226644578505966021501%2C6644578505966020088%22%3E%0A%3CDIV%20class%3D%22BMebGe%20btku5b%20LwdV0e%20FR7ZSc%20OJeuxf%22%20tabindex%3D%220%22%20role%3D%22button%22%20aria-label%3D%22Ver%20v%C3%ADnculos%20relacionados%22%20data-hveid%3D%22CCMQAQ%22%20data-ved%3D%222ahUKEwie_7vV85mQAxX6nu4BHUnYKH4Q3fYKegQIIxAB%22%3E%0A%3CDIV%20class%3D%22niO4u%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20id%3D%22aed9105b-4628-4749-8f80-e8d7c343bd47%22%20style%3D%22display%3A%20none%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20style%3D%22display%3A%20none%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CDIV%20class%3D%22zMgcWd%20dSKvsb%22%20data-il%3D%22%22%3E%0A%3CDIV%20data-crb-p%3D%22%22%3E%0A%3CDIV%20class%3D%22xFTqob%22%3E%0A%3CDIV%20class%3D%22Gur8Ad%22%20style%3D%22display%3A%20inline%3B%22%3E%3CSPAN%20data-huuid%3D%226644578505966021358%22%3E%3CSTRONG%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E9%96%8B%E7%99%BA%3A%3C%2FSTRONG%3E%20%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22vM0jzc%22%20style%3D%22display%3A%20inline%3B%22%3E%3CSPAN%20data-huuid%3D%226644578505966019945%22%3E%E6%9C%80%E8%BF%91%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%A7%E6%96%B0%E3%81%97%E3%81%84LUT%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%80%81PLL%E3%83%AD%E3%83%83%E3%82%AF%E6%A4%9C%E5%87%BA%E3%83%A1%E3%82%AB%E3%83%8B%E3%82%BA%E3%83%A0%E3%82%92%E8%AA%BF%E6%95%B4%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%81%8B%E3%82%89%E3%82%82%E3%82%8F%E3%81%8B%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%82%88%E3%82%8A%E5%A4%9A%E3%81%8F%E3%81%AE%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%80%81PLL%E8%A8%AD%E5%AE%9A%E3%82%92%E5%BE%AE%E8%AA%BF%E6%95%B4%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%92%E6%8B%A1%E5%BC%B5%E3%81%99%E3%82%8B%E5%8F%96%E3%82%8A%E7%B5%84%E3%81%BF%E3%81%8C%E7%B6%99%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22vM0jzc%22%20style%3D%22display%3A%20inline%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20class%3D%22vM0jzc%22%20style%3D%22display%3A%20inline%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20class%3D%22vM0jzc%22%20style%3D%22display%3A%20inline%3B%22%3E%3CSPAN%20data-huuid%3D%226644578505966019945%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2183577%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Custom%20HDMI%20Resolution%20on%20i.MX%208MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2183577%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%20Yocto%20Scarthgap%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E5%8F%96%E3%82%8A%E7%B5%84%E3%82%93%E3%81%A7%E3%81%8A%E3%82%8A%E3%80%81%20%3CSTRONG%3E3840x1080%20%40%2060Hz%3C%2FSTRONG%3E%E3%81%AE%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20HDMI%20%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AF%3CSTRONG%3E266.64%20MHz%3C%2FSTRONG%3E%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%2Fphy%2Ffreescale%2Fphy-fsl-samsung-hdmi.c%E3%81%AEsamsung_phy_pll_cfg%5B%5D%E9%85%8D%E5%88%97%E3%81%AB%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%EF%BC%9A%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EC%3C%2FSPAN%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CPRE%20translate%3D%22no%22%3E%7B%20%0A%20%20%20%20%3CSPAN%20class%3D%22%22%3E%2F%2F%203840x1080%4060Hz%20(266.64%20MHz)%3C%2FSPAN%3E%0A%20%20%20%20%3CSPAN%20class%3D%22%22%3E266640000%3C%2FSPAN%3E%2C%20%7B%0A%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22%22%3E0x00%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0xD1%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0x6B%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0x15%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0x89%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0x05%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0x88%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0x45%3C%2FSPAN%3E%2C%0A%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22%22%3E0x4F%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0x30%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0x33%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0x65%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0x30%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0xB8%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0x24%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0x80%3C%2FSPAN%3E%2C%0A%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22%22%3E0x6C%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0xF2%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0x67%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0x00%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0x10%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0x81%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0x30%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0x32%3C%2FSPAN%3E%2C%0A%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22%22%3E0x60%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0x8F%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0x00%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0x00%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0x08%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0x00%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0x00%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0x00%3C%2FSPAN%3E%2C%0A%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22%22%3E0x00%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0x80%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0x00%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0x00%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0x00%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0x00%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0x00%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0x00%3C%2FSPAN%3E%2C%0A%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22%22%3E0x00%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0xE0%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0x83%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0x0F%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0x3E%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0xF8%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0x00%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E0x00%3C%2FSPAN%3E%2C%0A%20%20%20%20%7D%2C%0A%7D%2C%3C%2FPRE%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%81%93%E3%81%AE%E5%A4%89%E6%9B%B4%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%A6%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AB%E4%BD%95%E3%82%82%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%20(%E9%BB%92%E3%81%84%E7%94%BB%E9%9D%A2)%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%20PHY%20PLL%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E5%80%A4%E3%81%8C%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%80%9D%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E4%B8%BB%E3%81%AA%E8%B3%AA%E5%95%8F%E3%81%AF%E3%80%81%3CSTRONG%3E%E7%89%B9%E5%AE%9A%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%E3%83%AC%E3%83%BC%E3%83%88%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%20Samsung%20HDMI%20PHY%20%E3%81%AE%E6%AD%A3%E3%81%97%E3%81%84%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E8%A8%AD%E5%AE%9A%E3%82%92%E7%94%9F%E6%88%90CAN%20PLL%20%E6%A7%8B%E6%88%90%E3%83%84%E3%83%BC%E3%83%AB%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%A7%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%81%AE%20Yocto%20Scarthgap%20%E7%92%B0%E5%A2%83%E3%81%A7%E3%81%AF%E3%83%93%E3%83%AB%E3%83%89%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%B3%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E6%9C%80%E6%96%B0%E3%81%AE%20phy-fsl-samsung-hdmi.c%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E3%81%9D%E3%81%AE%E3%81%BE%E3%81%BE%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%82%84%E6%8F%90%E6%A1%88%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E3%81%9C%E3%81%B2%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2180612%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Custom%20HDMI%20Resolution%20on%20i.MX%208MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2180612%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-huuid%3D%2218373906154512443152%22%3EHDMI%20%E7%B5%8C%E7%94%B1%E3%81%A7%203840x726%4060%20%E3%81%8A%E3%82%88%E3%81%B3%203840x1080%4060%20%E3%82%92%E5%AE%9F%E7%8F%BE%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%20data-huuid%3D%2218373906154512441845%22%3E%3CCODE%20class%3D%22mv6bHd%22%3Esamsung_phy%3C%2FCODE%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E6%AD%A3%E7%A2%BA%E3%81%AA%20HDMI%20PLL%20%E6%A7%8B%E6%88%90%E3%81%AF%E7%89%B9%E5%AE%9A%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%9F%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%81%A8%E3%83%AA%E3%83%95%E3%83%AC%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%AC%E3%83%BC%E3%83%88%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%87%E3%83%BC%E3%82%BF%20%E3%83%AC%E3%83%BC%E3%83%88%E3%81%AB%E5%90%88%E3%82%8F%E3%81%9B%E3%81%A6%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20(PCLK)%E3%80%81%E3%83%89%E3%83%83%E3%83%88%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%20TMDS%20(%E9%81%B7%E7%A7%BB%E6%9C%80%E5%B0%8F%E5%B7%AE%E5%8B%95%E4%BF%A1%E5%8F%B7)%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E8%AA%BF%E6%95%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20class%3D%22pjBG2e%22%20data-cid%3D%22dbf10ddf-2ab5-4c6f-81b5-c592ffb0f5b7%22%3E%3CSPAN%20class%3D%22UV3uM%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CDIV%20class%3D%22rPeykc%22%20data-hveid%3D%22CAMQAQ%22%20data-ved%3D%222ahUKEwiysbiU4Y-QAxXnj-4BHf7xApAQo_EKegQIAxAB%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CDIV%20class%3D%22rPeykc%20pyPiTc%22%20data-hveid%3D%22CAsQAQ%22%20data-ved%3D%222ahUKEwiysbiU4Y-QAxXnj-4BHf7xApAQo_EKegQICxAB%22%3E%3CSPAN%20data-huuid%3D%2214917545189639169299%22%3E1.%20%E5%BF%85%E8%A6%81%E3%81%AA%E5%B8%AF%E5%9F%9F%E5%B9%85%E3%82%92%E6%B1%BA%E5%AE%9A%E3%81%99%E3%82%8B%20%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CDIV%20class%3D%22rPeykc%20uP58nb%20MNX06c%22%20data-hveid%3D%22CAwQAQ%22%20data-ved%3D%222ahUKEwiysbiU4Y-QAxXnj-4BHf7xApAQo_EKegQIDBAB%22%3E%3CSPAN%20data-huuid%3D%2214917545189639171537%22%3E%3CSPAN%20aria-level%3D%222%22%3E%E3%81%BE%E3%81%9A%E3%80%81%E5%90%84%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%81%AE%E5%90%88%E8%A8%88%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%20%E3%83%AC%E3%83%BC%E3%83%88%20(%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%89%E3%83%83%E3%83%88%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF)%20%E3%82%92%E8%A8%88%E7%AE%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%20%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CUL%20data-hveid%3D%22CBAQAQ%22%20data-ved%3D%222ahUKEwiysbiU4Y-QAxXnj-4BHf7xApAQm_YKegQIEBAB%22%3E%0A%3CLI%3E%3CSPAN%20data-huuid%3D%2214917545189639168750%22%3E3840x726%4060Hz%20%3CSTRONG%3E%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20data-huuid%3D%2214917545189639171917%22%3E(3840%20*%20726%20*%2060)%20%2F%201%2C000%2C000%20%3D%20%E7%B4%84167.96%20MHz%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20data-huuid%3D%2214917545189639170059%22%3E3840x1080%4060Hz%20%3CSTRONG%3E%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20data-huuid%3D%2214917545189639169130%22%3E(3840%20*%201080%20*%2060)%20%2F%201%2C000%2C000%20%3D%20%E7%B4%84248.83%20MHz%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CDIV%20class%3D%22rPeykc%20uP58nb%22%20data-hveid%3D%22CBcQAQ%22%20data-ved%3D%222ahUKEwiysbiU4Y-QAxXnj-4BHf7xApAQo_EKegQIFxAB%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CDIV%20class%3D%22rPeykc%20pyPiTc%22%20data-hveid%3D%22CCQQAQ%22%20data-ved%3D%222ahUKEwiysbiU4Y-QAxXnj-4BHf7xApAQo_EKegQIJBAB%22%3E%3CSPAN%20data-huuid%3D%229448595434426010962%22%3E2.%20%3CCODE%20class%3D%22mv6bHd%22%3Esamsung_phy_%3C%2FCODE%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E6%A7%8B%E6%88%90%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CUL%20data-hveid%3D%22CC4QAQ%22%20data-ved%3D%222ahUKEwiysbiU4Y-QAxXnj-4BHf7xApAQm_YKegQILhAB%22%3E%0A%3CLI%3E%0A%3CDIV%20class%3D%22zMgcWd%20dSKvsb%22%20data-il%3D%22%22%3E%0A%3CDIV%20data-crb-p%3D%22%22%3E%0A%3CDIV%20class%3D%22xFTqob%22%3E%0A%3CDIV%20class%3D%22Gur8Ad%22%20style%3D%22display%3A%20inline%3B%22%3E%3CSPAN%20data-huuid%3D%229448595434426008551%22%3E%3CCODE%20class%3D%22mv6bHd%22%3Esamsung_phy_%3C%2FCODE%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22vM0jzc%22%20style%3D%22display%3A%20inline%3B%22%3E%3CSPAN%20data-huuid%3D%229448595434426008888%22%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AD%E3%83%B3%E3%82%B0%E3%81%A8%20PLL%20%E3%81%8C%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%88%B6%E5%BE%A1%E3%81%95%E3%82%8C%E3%82%8B%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20(%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%3CCODE%20class%3D%22mv6bHd%22%3Edrivers%2Fphy%2Fsamsung%2F%3C%2FCODE%3E%20)%20%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CDIV%20class%3D%22zMgcWd%20dSKvsb%22%20data-il%3D%22%22%3E%0A%3CDIV%20data-crb-p%3D%22%22%3E%0A%3CDIV%20class%3D%22xFTqob%22%3E%0A%3CDIV%20class%3D%22Gur8Ad%22%20style%3D%22display%3A%20inline%3B%22%3E%E6%97%A2%E5%AD%98%E3%81%AE%20PLL%20%E6%A7%8B%E6%88%90%E3%82%92%E8%AA%BF%E3%81%B9%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%0A%3CDIV%20class%3D%22vM0jzc%22%20style%3D%22display%3A%20inline%3B%22%3E%3CSPAN%20data-huuid%3D%229448595434426009899%22%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E5%86%85%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E7%94%9F%E6%88%90%E3%81%BE%E3%81%9F%E3%81%AF%20PLL%20%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E6%A9%9F%E8%83%BD%E3%82%92%E6%8E%A2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CDIV%20class%3D%22rPeykc%20uP58nb%22%20data-hveid%3D%22CDUQAQ%22%20data-ved%3D%222ahUKEwiysbiU4Y-QAxXnj-4BHf7xApAQo_EKegQINRAB%22%3E%3CSPAN%20data-huuid%3D%221286816788265072477%22%3E%3CSPAN%20aria-level%3D%222%22%3E3.%20PLL%E6%A7%8B%E6%88%90%E3%82%92%E8%AA%BF%E6%95%B4%E3%81%97%3C%2FSPAN%3E%3CSPAN%20class%3D%22pjBG2e%22%20data-cid%3D%22fde356fa-f8ce-4f83-b5d3-6008d14b91fc%22%3E%3CSPAN%20class%3D%22UV3uM%22%3E%E3%80%81dtb%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CDIV%20class%3D%22rPeykc%20uP58nb%22%20data-hveid%3D%22CDUQAQ%22%20data-ved%3D%222ahUKEwiysbiU4Y-QAxXnj-4BHf7xApAQo_EKegQINRAB%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CUL%20data-hveid%3D%22CDgQAQ%22%20data-ved%3D%222ahUKEwiysbiU4Y-QAxXnj-4BHf7xApAQm_YKegQIOBAB%22%3E%0A%3CLI%3E%3CSPAN%20data-huuid%3D%221286816788265073698%22%3EPLL%20(%E4%BD%8D%E7%9B%B8%E3%83%AD%E3%83%83%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%97)%20%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%82%92%E5%88%B6%E5%BE%A1%E3%81%99%E3%82%8B%3CCODE%20class%3D%22mv6bHd%22%3Esamsung_phy_%3C%2FCODE%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E5%86%85%E3%81%AE%E9%81%A9%E5%88%87%E3%81%AA%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20data-huuid%3D%221286816788265070823%22%3E%E5%B8%8C%E6%9C%9B%E3%81%99%E3%82%8B%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%3C%2FSPAN%3E%3CSPAN%20data-huuid%3D%221286816788265074512%22%3E%20%E6%AD%A3%E3%81%97%E3%81%84PCLK%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%ABPLL%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CSPAN%20data-huuid%3D%221286816788265070823%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
