Custom Camera Interface Through CSI Parallel Port
1,797件の閲覧回数
prasadadireddy
We are using a camera in which sensor is interfaced with FPGA.
The FPGA out (8 bit digital data, Frame Signals , clock and I2C signals) are connected to the esomimx6-micro board through CSI parallel port(CN10), please suggest how to stream video from CSI parallel port and store it into sd card
ラベル(6)
タグ(1)
1,634件の閲覧回数
joanxie
what camera and detailed mode do you  use? like gated clock mode or bt565 8bit mode?
