Cross compiling and debugging using eclipse environment
gurumoorthirasi
Hi imx forum,
i am newbie to imx25.
Anybody can please tel me step by step procedure to cross compiling and debugging the application code using eclipse environment?
and how can i add My application package into LTIB and how to build that particular app package?
Guru
Labels (2)
vishvapathi
Contributor V
Hi Guru,
Finally i succeeded intalling LTIB. Thanks for your feedback.
I made eclipse settings according to the below link
http://support.tq-group.com/doku.php?id=en:eclipse
I am getting error while building sample prog on eclipse
Building file: ../src/uart_appnote.c
Invoking: GCC C Compiler
/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/arm-fsl-linux-gnueabi/bin -I/home/vishva/Desktop/L3.0.35_4.0.0_130424_source/n/ltib/rpm/BUILD/linux-3.0.35/include -include/home/vishva/Desktop/L3.0.35_4.0.0_130424_source/n/ltib/rpm/BUILD/linux/lib/gen_crc32table -O0 -g3 -Wall -c -fmessage-length=0 -MMD -MP -MF"src/uart_appnote.d" -MT"src/uart_appnote.d" -o "src/uart_appnote.o" "../src/uart_appnote.c"
/bin/sh: /opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/arm-fsl-linux-gnueabi/bin: Permission denied
make: *** [src/uart_appnote.o] Error 126
vishvapathi
Contributor V
Hi Guru,
Did u find out about cross compilation procedure and adding application to LTIB???
gurumoorthirasi
Hi vishvapathi,
Thank you for your kind reply...first..
i have found the details for cross compilation ..i didn't get anything regarding debugging using eclipse environment.
vishvapathi
Contributor V
Hi Guru,
Can u share the details regarding cross compilation? i installed eclipse but i m not able to set the path to
" /opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-non
e-linux-gnueabi-gcc "
and while installing LTIB i am getting the following error
Processing: flex
Build path taken because: directory build, no prebuilt rpm,
Cowardly refusing to clobber existing directory:
/opt/freescale/ltib/usr/src/rpm/BUILD/flex-2.5.37
Remove this by hand if you really want to rebuild this package from scratch
Died at ./ltib line 1392.
traceback:
main::build_host_rpms:1392
  main::host_checks:1447
   main:554
any thoughts about it!!!
gurumoorthirasi
Goto this directory /opt/freescale/ltib/usr/src/rpm/BUILD/flex-2.5.37
and delete the flex-2.5.37 folder there
and run the ./ltib command.this would help you..i hope..
vishvapathi
Contributor V
Tried it... it didnt work out....
gurumoorthirasi
what error is showing on terminal/
gurumoorthirasi
install flex package on host then try..
vishvapathi
Contributor V
Error on Terminal:
Installing host support packages.
This only needs to be done once per host, but may take up to
an hour to complete ...
If an error occurs, a log file with the full output may be found in:
/home/vishva/Desktop/L3.0.35_4.0.0_130424_source/n/ltib/host_config.log
Exiting on error or interrupt
Please see >> /home/vishva/Desktop/L3.0.35_4.0.0_130424_source/n/ltib/host_config.log for details
Installed flex also...
sudo apt-get install flex
Reading package lists... Done
Building dependency tree
Reading state information... Done
flex is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
gurumoorthirasi
what is the log in host_config.log?
vishvapathi
Contributor V
Processing platform: Host support packages
using /home/vishva/Desktop/L3.0.35_4.0.0_130424_source/n/ltib/config/platform/host/ltib.preconfig
Processing: fake-provides
Processing: mkspooflinks
Processing: distcc
Processing: ccache
Processing: m4
Processing: bison
Processing: flex
traceback:
   main:554
Started: Wed Jun 12 10:36:34 2013
Ended:   Wed Jun 12 10:36:37 2013
Elapsed: 3 seconds
These packages failed to build:
flex
Build Failed
gurumoorthirasi
after removing from there ..it is showing the same?
vishvapathi
Contributor V
same error with more details...
missing --run makeinfo --version) >/dev/null 2>&1; then \
      for f in flex.info flex.info-[0-9] flex.info-[0-9][0-9] flex.i[0-9] flex.i[0-9][0-9]; do \
        if test -f $f; then mv $f $backupdir; restore=mv; else :; fi; \
      done; \
    else :; fi && \
    cd "$am__cwd"; \
    if /bin/bash /opt/freescale/ltib/usr/src/rpm/BUILD/flex-2.5.37/missing --run makeinfo   -I . \
     -o flex.info flex.texi; \
    then \
      rc=0; \
      CDPATH="${ZSH_VERSION+.}:" && cd .; \
    else \
      rc=$?; \
      CDPATH="${ZSH_VERSION+.}:" && cd . && \
      $restore $backupdir/* `echo "./flex.info" | sed 's|[^/]*$||'`; \
    fi; \
    rm -rf $backupdir; exit $rc
/opt/freescale/ltib/usr/src/rpm/BUILD/flex-2.5.37/missing: line 52: makeinfo: command not found
WARNING: `makeinfo' is missing on your system.  You should only need it if
         you modified a `.texi' or `.texinfo' file, or any other file
         indirectly affecting the aspect of the manual.  The spurious
         call might also be the consequence of using a buggy `make' (AIX,
         DU, IRIX).  You might want to install the `Texinfo' package or
         the `GNU make' package.  Grab either from any GNU archive site.
TEXINPUTS=".:$TEXINPUTS" \
    MAKEINFO='/bin/bash /opt/freescale/ltib/usr/src/rpm/BUILD/flex-2.5.37/missing --run makeinfo   -I .' \
    texi2dvi --pdf --batch flex.texi
/bin/bash: texi2dvi: command not found
make[2]: *** [flex.pdf] Error 127
make[2]: Leaving directory `/opt/freescale/ltib/usr/src/rpm/BUILD/flex-2.5.37/doc'
make[1]: *** [install-recursive] Error 1
make[1]: Leaving directory `/opt/freescale/ltib/usr/src/rpm/BUILD/flex-2.5.37'
make: *** [install] Error 2
error: Bad exit status from /home/vishva/Desktop/L3.0.35_4.0.0_130424_source/n/ltib/tmp/rpm-tmp.83759 (%install)
RPM build errors:
Build time for flex: 16 seconds
Failed building flex
traceback:
   main:554
Started: Wed Jun 12 11:40:07 2013
Ended:   Wed Jun 12 11:40:25 2013
Elapsed: 18 seconds
flex
Build Failed
gurumoorthirasi
install the `Texinfo' package then try
vishvapathi
Contributor V
Hi Guru,
After installing texinfo, i was able to select processor and futher installation continued, where i encountered another error
Internationalization
* The net-tools package has currently been translated to French,
* German and Brazilian Portugese.  Other translations are, of
* course, welcome.  Answer `n' here if you have no support for
* internationalization on your system.
Does your system support GNU gettext? (I18N) [n] make: *** [config.h] Error 1
error: Bad exit status from /home/vishva/Desktop/L3.0.35_4.0.0_130424_source/n/ltib/tmp/rpm-tmp.25647 (%build)
RPM build errors:
Build time for net-tools: 0 seconds
Failed building net-tools
f_buildrpms() returned an error, exiting
traceback:
main:572
Started: Wed Jun 12 11:57:30 2013
Ended:   Wed Jun 12 13:09:20 2013
Elapsed: 4310 seconds
net-tools
Build Failed
vishva@ubuntu:~/Desktop/L3.0.35_4.0.0_130424_source/n/ltib$ sudo apt-get install net-tools
[sudo] password for vishva:
net-tools is already the newest version.
vishva@ubuntu:~/Desktop/L3.0.35_4.0.0_130424_source/n/ltib$ sudo apt-get install gettext
gettext is already the newest version.
gurumoorthirasi
install package gettext and ja-trans then try again..
vishvapathi
Contributor V
Gettext is already installed and ja-trans is obsoleted,
vishva@ubuntu:~/Desktop/L3.0.35_4.0.0_130424_source/n/ltib$ sudo apt-get install ja-trans
Package ja-trans is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
  net-tools
E: Package ja-trans has no installation candidate
vishvapathi
Contributor V
Hi Guru,
gurumoorthirasi
Follow the below application notes for eclipse cross compilation.
it is working for me..
http://cache.freescale.com/files/dsp/doc/app_note/AN3870.pdf
