Cross-compile imx8 source code on Ubuntu 12.04
zc_tee
Dear all,
I am starting on imx8 development and would like to build some kernel/application on my Ubuntu 12.04 machine.
While I am looking for the cross compiler, i come across the article below:
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/Building-Linux-Kernel/ta-p/1110576#toc-h...
And, i found out that the gcc-aarch64-linux-gnu, is not support on 12.04. It's only support from 14.04 onwards.
Is it possible to copy the cross-compiler for imx8 and use on Ubuntu 12.04? Is there any link where I can download the cross-compiler?
Thank you.
Tee
Zhiming_Liu
Yes ,it's must be ubuntu16.04+
zc_tee
Thank you for your confirmation
Tee
Zhiming_Liu
Ubuntu 16.04 is our lowest requirement to build our bsp
Zhiming
zc_tee
Hi @Zhiming_Liu ,
How about only building the kernel source code? Does it requires Ubuntu 16.04 and above too?
Tee
Zhiming_Liu
