Cross compile and debugging of imx7d application
1,809 次查看
maash
Hi.
We are using IM7D picopi board with yocto. Currently we add libraries in yocto recepie and some we compile on target. However we would like to cross compile the applications in separate workstation and there doesn't seem to be any instructions regarding the workflow on imx7d.
Also is there more convenient way to add libraries than adding them on yocto build?
标签 (2)
标记 (3)
1,536 次查看
gusarambula
Hello Matti,
You can cross compile for the i.MX7 by extracting the toolchain for this processor.
You can extract the toolchain by running the same command within the yocto environment:
$ bitbake meta-toolchain
It would result on a script that you can run to install the toolchain with the settings for your machine.
I hope this information helps!
1,536 次查看
maash
Hi Gusarambula.
Thanks. This is good starting point!
Is there perhaps related tutorial about environment setup, debugging and such? I would like to get eclipse environment and debugger working.
-Matti
1,536 次查看
gusarambula
Hello Matti,
There is a document that may be helpful, although it's not very recent the principles still stand:
https://community.nxp.com/docs/DOC-172840
I hope this helps!
