Creating own recipe in yocto
2,389 次查看
manjunathjoshi
Hello all,
Is there any way that we can create a recipe which can simply copy a file from host computer to the bitbake process so that after the complete bitbake process we may just have the file in the right place in yocto filesystem?
I know this is weird but is there a way? I tried as shown below it didn't work. do_install failure.
this is the .bb file in a new layer i have created.
SUMMARY = "Example to copy from my filesystem to yocto filesystem"
DESCRIPTION = "Not needed"
SECTION = "examples"
LICENSE = "MIT"
LIC_FILES_CHKSUM += "file://README;md5=0d20a0079cbd6add839dcca5f80c7d0b"
PR = "r0"
DEPENDS = "boost"
SRC_URI="file://README \
S="${WORKDIR}"
do_install() {
     install -m 0755 ${WORKDIR}/README  ${D}$/usr/sbin/README
Manju
标签 (3)
1,738 次查看
gusarambula
Hello Manju,
Your recipe looks good in general but it may need some tweaking. Would you please try with the following changes? (The first part of the recipe looks good).
do_install() {
   install -d  ${D}$/usr/sbin/
FILES_${PN} = "$/usr/sbin/README"
I hope this helps, let us know of your progress! One would think that copying a file into the filesystem should be pretty straightforward but it’s not so trivial in Yocto. I’m sure other community users may have the same question.
Gus
1,739 次查看
gusarambula
Hello Manju,
do_install() {
Gus
1,738 次查看
manjunathjoshi
Hello gusarambula,
I am sorry i didn't update this on the community. Your answer is right i have already done this. But right now i am in to writing a recipe which does every bit of a standard one. I have posted the same in
Custom recipe for YOCTO
Please reply if you have needed information on the same.
Thanks a lot in advance.
Manju
