- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
Qt5_CinematicExperience -platform eglfs
result:
QEglFSImx6Hooks will set environment variable FB_MULTI_BUFFER=2 to enable double buffering and vsync.
If this is not desired, you can override this via: export QT_EGLFS_IMX6_NO_FB_MULTI_BUFFER=1
Could not open egl display
then i set FB_MULTI_BUFFER=2 or QT_EGLFS_IMX6_NO_FB_MULTI_BUFFER=1
result:
root@imx6qsabresd:~# Qt5_CinematicExperience -platform eglfs
/usr/bin/Qt5_CinematicExperience: line 4: 432 Aborted /usr/share/cinematicexperience-1.0/Qt5_CinematicExperience $*
kernel:3.14.28
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I have also this problem. I exported Display and applied Andrey's recommendation. it still gives same error could not open display
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
can you show full error log?
i make some changes to unify my scripts
#!/bin/sh
fb=/dev/fb$1
export QT_QPA_FONTDIR=/usr/share/fonts/
export QT_QPA_EGLFS_FORCEVSYNC=1
export QT_QPA_EGLFS_HIDECURSOR=1
export QT_QPA_EGLFS_FB=$fb
export FB_FRAMEBUFFER_0=$fb
export QT_QPA_PLATFORM=eglfs
export LANG=ru_RU.UTF-8
/path/to/program
now to start program on some display you can set framebuffer number
script.sh 2 &
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
before your script
QEglFSVivIntegration will set environment variable FB_MULTI_BUFFER=2 to enable double buffering and vsync.
Aborted
after yourscript
Aborted
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
which framebuffer you using?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I have check my frame buffer. I have just fb0. I changed fb=/dev/fb$1 with fb=/dev/fb$0 and error :
EGLFS: Failed to open /dev/fb-sh
EGLFS: Can't continue without a display
Aborted
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
for you my script whill be
#!/bin/sh
fb=/dev/fb0
/path/to/program
show output of this command
cat /sys/class/graphics/fb0/mode
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
same error
Aborted
mode file is empty
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
its look like something wrong with your framebuffer driver. What board are you using and what linux on it?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
linux 4.11.4
board karo tx6u 8033
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
can you show tree under /usr/lib/qt/plugins/egldeviceintegrations
mine is
# cd /usr/lib/qt/plugins/egldeviceintegrations
# tree
|-- libqeglfs-kms-egldevice-integration.so
`-- libqeglfs-kms-integration.so0 directories, 2 files
must there be a libqeglfs_viv something like that? do I have missing file here?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
root@MMC:~# tree /usr/lib/qt5/plugins/egldeviceintegrations/
`-- libqeglfs-viv-integration.so
0 directories, 1 file
root@MMC:~#
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I am using buildroot, I select imx-gpu-viv and qt5 egl support. however egl vivante integration is missing. I gues there is bug on integration of vivante for buildroot.
thank you Andrey
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
i'm using yocto, you can try it
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
which board do you use? mine is karo
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
yes I want to switch to yocto too, because imx does not support buildroot also buildroot community is not so wide as yocto. do you have any suggestion where to start?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
i think better way to start from here, but take pyro branch, not dora like on this link, other the same
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
OP, could u please explain ur solution? Exporting DISPLAY doesn't work for me.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
#!/bin/sh
export QT_QPA_EGLFS_FB=/dev/fb0
export FB_FRAMEBUFFER_0=/dev/fb0
/home/root/program &
work for me now
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
i have the same error, build yocto image jethro + Qt make start script
root@imx6qsabreauto:~# cat /bin/start.sh
#!/bin/sh
export LD_LIBRARY_PATH=/usr/lib
export QML_IMPORT_PATH=/usr/lib/qt5/qml
export QML2_IMPORT_PATH=/usr/lib/qt5/qml
export QT_QPA_PLATFORM_PLUGIN_PATH=/lib/qt5/plugins/platforms
export QT_QPA_EGLFS_PHYSICAL_WIDTH=1920
export QT_QPA_EGLFS_PHYSICAL_HEIGTH=1080
#export QT_QPA_EGLFS_FB=/dev/fb2
#export FB_FRAMEBUFFER_0=/dev/fb2
export DISPLAY=:0.0
and still have same error
root@imx6qsabreauto:~# start.sh
/bin/start.sh: line 12: 458 Aborted Qt5_CinematicExperience
