Could not open egl display
481,721 次查看
强王
Qt5_CinematicExperience -platform eglfs
result:
QEglFSImx6Hooks will set environment variable FB_MULTI_BUFFER=2 to enable double buffering and vsync.
If this is not desired, you can override this via: export QT_EGLFS_IMX6_NO_FB_MULTI_BUFFER=1
then i set FB_MULTI_BUFFER=2 or QT_EGLFS_IMX6_NO_FB_MULTI_BUFFER=1
result:
root@imx6qsabresd:~# Qt5_CinematicExperience -platform eglfs
/usr/bin/Qt5_CinematicExperience: line 4:   432 Aborted                 /usr/share/cinematicexperience-1.0/Qt5_CinematicExperience $*
kernel:3.14.28
标签 (4)
474,313 次查看
Bio_TICFSL
Hi Qiang
Did you try export DISPLAY ?
21 回复数
474,314 次查看
Bio_TICFSL
Hi Qiang
