My purpose is to convert Raw File to Jpeg in i.MX8MP.
I am using encoder_test in imx-test-lf-5.15.32_2.0.0.
There is no JPEG in mxc_isi_out_format(in kernel isi), so the following error occurs.
"isi-m2m 32e00000.isi:m2m_device: mxc_isi_m2m_s_fmt_vid_cap, format is not support!"
Is it possible to fix the problem? Or should I use another method?
Solved! Go to Solution.
current imx8mp HW doesn't have such convert function, customer needs do it by their own SW
