Convert 8bit grayscale buffer to be accepted by vpuenc gstreamer element?
1,414件の閲覧回数
chriswhittenbur
I have a monochrom image sensor connected to my imx6q board, capturing 30fps 1280x960 8bit grayscale images using gstreamer and the mfw_v4lsrc element.  Converting from 8bit grayscale to I420 should be quick, but it appears memcpy out of a dma coherent buffer is very inefficient.  What other tricks can I use to do this in hardware?  Converting to I420 should involve just growing the buffer by 614,400 bytes and filling that area with 128.
ラベル(3)
1,019件の閲覧回数
joanxie
how did you change capture the grayscale? one can use the mxc_v4l2_capture.out to test, maybe you can give me the mail address, I can send the demo code for how to capture 8bit grayscale data to you. or if you have already create SR, pls tell me the SR number. I posted here failed.
