Content in imx93 timer is not executed.
1,240件の閲覧回数
xiang_1001
bsp:real-time-edge-3.1.0.xml
The /etc/net-debug.sh file is executed regularly in /etc/crontab, but now this script doesn't run. What is the reason?
1,208件の閲覧回数
Bio_TICFSL
Common Reasons for a Failed Cron Job
  • Permissions: The script lacks execute permissions. You need to make the script executable using chmod +x /path/to/your/script.sh.
  • Path Environment Variable: Cron runs scripts in a minimal environment with a restricted PATH. Commands within the script may not be found.
  • Missing or Incorrect Paths:
    • The crontab entry itself might use relative paths, which is problematic for cron.
    • The script might not specify the full path to commands it calls (e.g., instead of ls, use /bin/ls).
  • Crontab Syntax Errors:
    • There must be a newline character after the last command in the crontab file.
    • The user field is missing in the /etc/crontab file, which requires a user name before the command.
  •   Issues:
    • The script may rely on environment variables that are not set in the minimal cron environment.
    • Scripts containing non-text characters can cause failures
Troubleshooting Steps
  1. Log Script Output: Redirect the script's output to a log file to see any error messages.
    bash
  • * * * * * /path/to/your/script.sh >> /var/log/your_script.log 2>&1
  • Check Permissions: Use ls -l /path/to/your/script.sh to verify the script has execute (x) permissions. If not, run chmod +x /path/to/your/script.sh.
  • Use Full Paths: In your script, replace relative path commands with their full paths (e.g., /bin/grep instead of grep).
  • Set Environment Variables: Add PATH and other necessary variables at the top of your cron entry or script to define the environment.
  • Check for Newline: Open /etc/crontab and ensure there is a new line character after the last command in your entry.
  • Verify User Field: For /etc/crontab, ensure the user field is present (e.g., root).
  • Use cron.d: For root-owned jobs, consider placing them in /etc/cron.d/ instead of directly editing /etc/crontab for better organization
2 返答(返信)
1,209件の閲覧回数
Bio_TICFSL
  •   Issues:
    bash
1,134件の閲覧回数
xiang_1001
I can use the timing function by putting the crontab file into the /etc/cron.d/ file.
%3CLINGO-SUB%20id%3D%22lingo-sub-2177861%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eimx93%20%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%81%AE%E5%86%85%E5%AE%B9%E3%81%AF%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2177861%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ebsp%EF%BC%9A%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A8%E3%83%83%E3%82%B8%203.1.0.xml%3C%2FP%3E%3CP%3E%2Fetc%2Fnet-debug.sh%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%20%2Fetc%2Fcrontab%20%E5%86%85%E3%81%A7%E5%AE%9A%E6%9C%9F%E7%9A%84%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E7%8F%BE%E5%9C%A8%E3%81%93%E3%81%AE%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%AF%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E7%90%86%E7%94%B1%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22xiang_1001_0-1759204650814.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xiang_1001_0-1759204650814.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F358985i98A632736428BB9A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22xiang_1001_0-1759204650814.png%22%20alt%3D%22xiang_1001_0-1759204650814.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Exiang_1001_0-1759204650814.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2183402%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Content%20in%20imx93%20timer%20is%20not%20executed.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2183402%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ecrontab%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%2Fetc%2Fcron.d%2F%E3%81%AB%E7%BD%AE%E3%81%8F%E3%81%93%E3%81%A8%E3%81%A7%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E6%A9%9F%E8%83%BDCAN%E3%80%82%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2178264%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Content%20in%20imx93%20timer%20is%20not%20executed.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2178264%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3ECron%E3%82%B8%E3%83%A7%E3%83%96%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%99%E3%82%8B%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E7%90%86%E7%94%B1%3C%2FP%3E%0A%3CDIV%20class%3D%22Y3BBE%22%20data-hveid%3D%22CAIQAA%22%20data-processed%3D%22true%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CBR%20%2F%3E%0A%3CUL%3E%0A%3CLI%20data-hveid%3D%22CAMQAA%22%20data-processed%3D%22true%22%3E%3CSPAN%20class%3D%22T286Pc%22%20data-processed%3D%22true%22%3E%E6%A8%A9%E9%99%90%3CSTRONG%20class%3D%22Yjhzub%22%20data-processed%3D%22true%22%3E%3A%3C%2FSTRONG%3E%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%AB%E3%81%AF%E5%AE%9F%E8%A1%8C%E6%A8%A9%E9%99%90%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CCODE%20class%3D%22o8j0Mc%22%20data-processed%3D%22true%22%3Echmod%20%2Bx%20%2Fpath%2Fto%2Fyour%2Fscript.sh%3C%2FCODE%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E5%AE%9F%E8%A1%8C%E5%8F%AF%E8%83%BD%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20data-hveid%3D%22CAMQAQ%22%20data-processed%3D%22true%22%3E%3CSPAN%20class%3D%22T286Pc%22%20data-processed%3D%22true%22%3E%E3%83%91%E3%82%B9%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%3A%20cron%20%E3%81%AF%E3%80%81%20%3CSPAN%20data-processed%3D%22true%22%3E%3CCODE%20class%3D%22o8j0Mc%22%20data-processed%3D%22true%22%3EPATH%3C%2FCODE%3E%3C%2FSPAN%3E%E3%81%8C%E5%88%B6%E9%99%90%E3%81%95%E3%82%8C%E3%81%9F%E6%9C%80%E5%B0%8F%E9%99%90%E3%81%AE%E7%92%B0%E5%A2%83%E3%81%A7%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%3CSPAN%20data-processed%3D%22true%22%3E%E3%80%82%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E5%86%85%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CUL%3E%0A%3CLI%20data-hveid%3D%22CAMQAg%22%20data-processed%3D%22true%22%3E%3CSPAN%20class%3D%22T286Pc%22%3E%E3%83%91%E3%82%B9%E3%81%8C%E6%AC%A0%E8%90%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3A%3C%2FSPAN%3E%0A%3CUL%20class%3D%22U6u95%22%3E%0A%3CLI%20data-hveid%3D%22CAMQAw%22%3E%3CSPAN%20class%3D%22T286Pc%22%3Ecrontab%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E8%87%AA%E4%BD%93%E3%81%8C%E7%9B%B8%E5%AF%BE%E3%83%91%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%20cron%20%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E5%95%8F%E9%A1%8C%E3%81%A8%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20data-hveid%3D%22CAMQBA%22%3E%3CSPAN%20class%3D%22T286Pc%22%3E%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%99%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%B8%E3%81%AE%E5%AE%8C%E5%85%A8%E3%81%AA%E3%83%91%E3%82%B9%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%20(%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81%20%3CCODE%20class%3D%22o8j0Mc%22%3Els%3C%2FCODE%3E%E3%81%AE%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%3CCODE%20class%3D%22o8j0Mc%22%3E%2Fbin%2Fls%3C%2FCODE%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99)%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CUL%3E%0A%3CLI%20data-hveid%3D%22CAMQBQ%22%20data-processed%3D%22true%22%3E%3CSPAN%20class%3D%22T286Pc%22%3ECrontab%20%E6%A7%8B%E6%96%87%E3%82%A8%E3%83%A9%E3%83%BC%3A%3C%2FSPAN%3E%0A%3CUL%20class%3D%22U6u95%22%3E%0A%3CLI%20data-hveid%3D%22CAMQBg%22%3E%3CSPAN%20class%3D%22T286Pc%22%3Ecrontab%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E6%9C%80%E5%BE%8C%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E5%BE%8C%E3%81%AB%E3%81%AF%E6%94%B9%E8%A1%8C%E6%96%87%E5%AD%97%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20data-hveid%3D%22CAMQBw%22%3E%3CSPAN%20class%3D%22T286Pc%22%3E%3CCODE%20class%3D%22o8j0Mc%22%3E%2Fetc%2Fcrontab%3C%2FCODE%3E%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%3CCODE%20class%3D%22o8j0Mc%22%3E%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%20%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E5%89%8D%E3%81%AB%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E5%90%8D%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FCODE%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CUL%3E%0A%3CLI%20data-hveid%3D%22CAMQCA%22%20data-processed%3D%22true%22%3E%3CSPAN%20class%3D%22T286Pc%22%3E%3CSTRONG%20class%3D%22Yjhzub%22%3E%E5%95%8F%E9%A1%8C%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%0A%3CUL%20class%3D%22U6u95%22%3E%0A%3CLI%20data-hveid%3D%22CAMQCg%22%3E%3CSPAN%20class%3D%22T286Pc%22%3E%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%AF%E3%80%81%E6%9C%80%E5%B0%8F%E9%99%90%E3%81%AE%20cron%20%E7%92%B0%E5%A2%83%E3%81%A7%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%E3%81%AB%E4%BE%9D%E5%AD%98%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20data-hveid%3D%22CAMQCw%22%3E%3CSPAN%20class%3D%22T286Pc%22%3E%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E4%BB%A5%E5%A4%96%E3%81%AE%E6%96%87%E5%AD%97%E3%82%92%E5%90%AB%E3%82%80%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%AF%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E5%BC%95%E3%81%8D%E8%B5%B7%E3%81%93%E3%81%99%20CAN%20%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3CDIV%20class%3D%22Y3BBE%22%20data-hveid%3D%22CAQQAA%22%20data-processed%3D%22true%22%3E%3CSTRONG%20class%3D%22Yjhzub%22%3E%E3%83%88%E3%83%A9%E3%83%96%E3%83%AB%E3%82%B7%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%AE%E6%89%8B%E9%A0%86%3C%2FSTRONG%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22Y3BBE%22%20data-hveid%3D%22CAQQAA%22%20data-processed%3D%22true%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3COL%20class%3D%22VimKh%22%20data-processed%3D%22true%22%3E%0A%3CLI%20data-hveid%3D%22CAcQAA%22%3E%3CSPAN%20class%3D%22T286Pc%22%3E%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%AE%E5%87%BA%E5%8A%9B%E3%82%92%E3%83%AD%E3%82%B0%E3%81%AB%E8%A8%98%E9%8C%B2%3CSTRONG%20class%3D%22Yjhzub%22%3E%3A%3C%2FSTRONG%3E%E3%82%A8%E3%83%A9%E3%83%BC%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%AE%E5%87%BA%E5%8A%9B%E3%82%92%E3%83%AD%E3%82%B0%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%83%AA%E3%83%80%E3%82%A4%E3%83%AC%E3%82%AF%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%0A%3CDIV%20class%3D%22r1PmQe%22%20data-wiz-uids%3D%22GKze5d_4e%2CGKze5d_4f%2CGKze5d_4g%22%20data-hveid%3D%22CAcQAQ%22%3E%0A%3CDIV%3E%0A%3CDIV%20class%3D%22pHpOfb%22%20data-animation-atomic%3D%22%22%3E%0A%3CDIV%20class%3D%22vVRw1d%22%3E%E3%83%90%E3%83%83%E3%82%B7%E3%83%A5%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%3CLI-WRAPPER%3E%3C%2FLI-WRAPPER%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%20data-hveid%3D%22CAcQAA%22%3E%0A%3CDIV%20class%3D%22r1PmQe%22%20data-wiz-uids%3D%22GKze5d_4e%2CGKze5d_4f%2CGKze5d_4g%22%20data-hveid%3D%22CAcQAQ%22%3E%0A%3CDIV%3E%0A%3CDIV%20class%3D%22pHpOfb%22%20data-animation-atomic%3D%22%22%3E%0A%3CDIV%20class%3D%22pCTyYe%22%3E%0A%3CPRE%20translate%3D%22no%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20class%3D%22undefined%22%3E*%20*%20*%20*%20*%20%2Fpath%2Fto%2Fyour%2Fscript.sh%20%26gt%3B%26gt%3B%20%2Fvar%2Flog%2Fyour_script.log%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22tnfcCf%22%3E2%3C%2FSPAN%3E%3CSPAN%20class%3D%22undefined%22%3E%26gt%3B%26amp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22tnfcCf%22%3E1%3C%2FSPAN%3E%0A%3C%2FCODE%3E%3C%2FPRE%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FLI%3E%0A%3CLI%20data-hveid%3D%22CAcQAw%22%3E%3CSPAN%20class%3D%22T286Pc%22%3E%E6%A8%A9%E9%99%90%E3%81%AE%E7%A2%BA%E8%AA%8D%3A%20%3CCODE%20class%3D%22o8j0Mc%22%3Els%20-l%20%2Fpath%2Fto%2Fyour%2Fscript.sh%3C%2FCODE%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%AB%E5%AE%9F%E8%A1%8C%20(%20%3CCODE%20class%3D%22o8j0Mc%22%3Ex%3C%2FCODE%3E%20)%20%E6%A8%A9%E9%99%90%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%20%3CCODE%20class%3D%22o8j0Mc%22%3Echmod%20%2Bx%20%2Fpath%2Fto%2Fyour%2Fscript.sh%3C%2FCODE%3E%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20data-hveid%3D%22CAcQBA%22%3E%3CSPAN%20class%3D%22T286Pc%22%3E%E3%83%95%E3%83%AB%E3%83%91%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3A%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E5%86%85%E3%81%A7%E3%80%81%E7%9B%B8%E5%AF%BE%E3%83%91%E3%82%B9%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E3%83%95%E3%83%AB%E3%83%91%E3%82%B9%E3%81%AB%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%81%BE%E3%81%99%20(%E4%BE%8B%3A%3CCODE%20class%3D%22o8j0Mc%22%3E%20grep%3C%2FCODE%3E%20%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%3CCODE%20class%3D%22o8j0Mc%22%3E%20%2Fbin%2Fgrep%3C%2FCODE%3E%20)%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20data-hveid%3D%22CAcQBQ%22%3E%3CSPAN%20class%3D%22T286Pc%22%3E%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%3A%20%E7%92%B0%E5%A2%83%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81cron%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%AE%E5%85%88%E9%A0%AD%E3%81%AB%3CCODE%20class%3D%22o8j0Mc%22%3EPATH%3C%2FCODE%3E%E3%82%84%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E5%BF%85%E8%A6%81%E3%81%AA%E5%A4%89%E6%95%B0%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20data-hveid%3D%22CAcQBg%22%3E%3CSPAN%20class%3D%22T286Pc%22%3E%E6%94%B9%E8%A1%8C%E6%96%87%E5%AD%97%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%3CSTRONG%20class%3D%22Yjhzub%22%3E%3A%3C%2FSTRONG%3E%20%3CCODE%20class%3D%22o8j0Mc%22%3E%2Fetc%2Fcrontab%3C%2FCODE%3E%E3%82%92%E9%96%8B%E3%81%8D%E3%80%81%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%81%AE%E6%9C%80%E5%BE%8C%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E5%BE%8C%E3%81%AB%E6%94%B9%E8%A1%8C%E6%96%87%E5%AD%97%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20data-hveid%3D%22CAcQBw%22%3E%3CSPAN%20class%3D%22T286Pc%22%3E%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%20%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%E3%81%AE%E7%A2%BA%E8%AA%8D%3CSTRONG%20class%3D%22Yjhzub%22%3E%3A%3C%2FSTRONG%3E%20%3CCODE%20class%3D%22o8j0Mc%22%3E%2Fetc%2Fcrontab%3C%2FCODE%3E%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%20%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%E3%81%8C%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%20(%E4%BE%8B%3A%20%3CCODE%20class%3D%22o8j0Mc%22%3Eroot%3C%2FCODE%3E%20)%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20data-hveid%3D%22CAcQCA%22%3E%3CSPAN%20class%3D%22T286Pc%22%3E%3CSTRONG%20class%3D%22Yjhzub%22%3E%3CCODE%20class%3D%22o8j0Mc%22%3Ecron.d%3C%2FCODE%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3A%3C%2FSTRONG%3E%E3%83%AB%E3%83%BC%E3%83%88%E6%89%80%E6%9C%89%E3%81%AE%E3%82%B8%E3%83%A7%E3%83%96%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%20%3CCODE%20class%3D%22o8j0Mc%22%3E%2Fetc%2Fcron.d%2F%3C%2FCODE%3E%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%A4%9C%E8%A8%8E%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%82%88%E3%82%8A%E8%89%AF%E3%81%84%E6%A7%8B%E6%88%90%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%3CCODE%20class%3D%22o8j0Mc%22%3E%2Fetc%2Fcrontab%3C%2FCODE%3E%E3%82%92%E7%9B%B4%E6%8E%A5%E7%B7%A8%E9%9B%86%E3%81%99%E3%82%8B%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CSPAN%20class%3D%22T286Pc%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
