Connecting Ethernet using USB adapter
655 次查看
EmbeddedTech
I would like to connect my board to host PC via Ethernet. But in our actual board we will not be having the Ethernet socket on our hardware. So we would like to use the USB Ethernet adapter to connect to the host PC. Is there any sample code in the SDK which I can try for this? Is the evkmimxrt1060_dev_cdc_vnic_freertos support the above requirement?
I tired downloading that code but got the following terminal message,
PHY Link down, please check the cable connection.
USB device CDC virtual nic demo
Any help on this is highly appreciated.
0 回复数
