Config Tools v26.06
Config Tools v26.06
simonng
Hi NXP,
I upgraded the Config Tools from v25.3 to v25.6.
When I ran the DDR Test, I got the following error. It has no problem if I use v25.3 to run the test. How to solve this problem with the latest v25.6?
Simon
################### Result for: phy_init ###### Run 1 #############################################Microsoft Windows [Version 10.0.26100.4652]
(c) Microsoft Corporation. All rights reserved.
C:\nxp\i.MX_CFG_25.06\bin>prompt test-prefix :
test-prefix : "C:/nxp/i.MX_CFG_25.06/bin/python3/python" "C:/nxp/i.MX_CFG_25.06/bin/python3/memtool/memtool_entry.py" -t "runtest" -d "C:/ProgramData/NXP/mcu_data_25.06/processors/MIMX9596xxxxN/ksdk2_0/mem_validation/ddrc" -p "C:/Users/eg_fw/AppData/Local/Temp/mem_validation/phy_training_phy_test_0_0_.log" -l INFO "C:/Users/eg_fw/AppData/Local/Temp/mem_validation/connect.json" "C:/Users/eg_fw/AppData/Local/Temp/mem_validation/test.json" "C:/Users/eg_fw/AppData/Local/Temp/mem_validation/phy.json" "C:/Users/eg_fw/AppData/Local/Temp/mem_validation/ddrc_registers.json" "C:/Users/eg_fw/AppData/Local/Temp/mem_validation/ddrc_config.json" "C:/Users/eg_fw/AppData/Local/Temp/mem_validation/ddrc_config_in.json"
INFO memtool.utils.helper *****C:/Users/eg_fw/AppData/Local/Temp/mem_validation/connect.json
INFO memtool.utils.helper *****C:/Users/eg_fw/AppData/Local/Temp/mem_validation/test.json
INFO memtool.utils.helper *****C:/Users/eg_fw/AppData/Local/Temp/mem_validation/phy.json
INFO memtool.utils.helper *****C:/Users/eg_fw/AppData/Local/Temp/mem_validation/ddrc_registers.json
INFO memtool.utils.helper *****C:/Users/eg_fw/AppData/Local/Temp/mem_validation/ddrc_config.json
INFO memtool.utils.helper *****C:/Users/eg_fw/AppData/Local/Temp/mem_validation/ddrc_config_in.json
INFO memtool.processor.imx9.imx9_processor Xls mapping load time 0.037542
INFO memtool.processor.imx9.imx9_processor Config time 0.000289
INFO memtool.processor.imx9.imx9_processor DS file time 0.281771
INFO memtool.phyinit.phy_init Run phyinit for 2024.09\lpddr5
INFO memtool.comm.serial_channel Using serial: COM27
ERROR memtool.common.base_test Application load ended with exception: Download incomplete due to configuration error!
pengyong_zhang
Hi @simonng
For the latest Config Tool version 25.06, we only support imx95 chip B0 version, i think your chip is also A1 or A0 version, you need to use the before version tool run the DDR relate test of i.MX95.
B.R
%3CLINGO-SUB%20id%3D%22lingo-sub-2138789%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EConfig%20Tools%20v26.06%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2138789%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20NXP%2C%3C%2FP%3E%3CP%3EI%20upgraded%20the%20Config%20Tools%20from%20v25.3%20to%20v25.6.%3C%2FP%3E%3CP%3EWhen%20I%20ran%20the%20DDR%20Test%2C%20I%20got%20the%20following%20error.%20It%20has%20no%20problem%20if%20I%20use%20v25.3%20to%20run%20the%20test.%20How%20to%20solve%20this%20problem%20with%20the%20latest%20v25.6%3F%3C%2FP%3E%3CP%3EThanks%2C%3C%2FP%3E%3CP%3ESimon%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CP%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20Result%20for%3A%20phy_init%20%23%23%23%23%23%23%20Run%201%20%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23Microsoft%20Windows%20%5BVersion%2010.0.26100.4652%5D%3C%2FP%3E%3CP%3E(c)%20Microsoft%20Corporation.%20All%20rights%20reserved.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EC%3A%5Cnxp%5Ci.MX_CFG_25.06%5Cbin%26gt%3Bprompt%20test-prefix%20%3A%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Etest-prefix%20%3A%20%22C%3A%2Fnxp%2Fi.MX_CFG_25.06%2Fbin%2Fpython3%2Fpython%22%20%22C%3A%2Fnxp%2Fi.MX_CFG_25.06%2Fbin%2Fpython3%2Fmemtool%2Fmemtool_entry.py%22%20-t%20%22runtest%22%20-d%20%22C%3A%2FProgramData%2FNXP%2Fmcu_data_25.06%2Fprocessors%2FMIMX9596xxxxN%2Fksdk2_0%2Fmem_validation%2Fddrc%22%20-p%20%22C%3A%2FUsers%2Feg_fw%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fphy_training_phy_test_0_0_.log%22%20-l%20INFO%20%22C%3A%2FUsers%2Feg_fw%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fconnect.json%22%20%22C%3A%2FUsers%2Feg_fw%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Ftest.json%22%20%22C%3A%2FUsers%2Feg_fw%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fphy.json%22%20%22C%3A%2FUsers%2Feg_fw%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fddrc_registers.json%22%20%22C%3A%2FUsers%2Feg_fw%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fddrc_config.json%22%20%22C%3A%2FUsers%2Feg_fw%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fddrc_config_in.json%22%3C%2FP%3E%3CP%3EINFO%20memtool.utils.helper%20*****C%3A%2FUsers%2Feg_fw%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fconnect.json%3C%2FP%3E%3CP%3EINFO%20memtool.utils.helper%20*****C%3A%2FUsers%2Feg_fw%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Ftest.json%3C%2FP%3E%3CP%3EINFO%20memtool.utils.helper%20*****C%3A%2FUsers%2Feg_fw%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fphy.json%3C%2FP%3E%3CP%3EINFO%20memtool.utils.helper%20*****C%3A%2FUsers%2Feg_fw%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fddrc_registers.json%3C%2FP%3E%3CP%3EINFO%20memtool.utils.helper%20*****C%3A%2FUsers%2Feg_fw%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fddrc_config.json%3C%2FP%3E%3CP%3EINFO%20memtool.utils.helper%20*****C%3A%2FUsers%2Feg_fw%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fddrc_config_in.json%3C%2FP%3E%3CP%3EINFO%20memtool.processor.imx9.imx9_processor%20Xls%20mapping%20load%20time%200.037542%3C%2FP%3E%3CP%3EINFO%20memtool.processor.imx9.imx9_processor%20Config%20time%200.000289%3C%2FP%3E%3CP%3EINFO%20memtool.processor.imx9.imx9_processor%20DS%20file%20time%200.281771%3C%2FP%3E%3CP%3EINFO%20memtool.phyinit.phy_init%20Run%20phyinit%20for%202024.09%5Clpddr5%3C%2FP%3E%3CP%3EINFO%20memtool.comm.serial_channel%20Using%20serial%3A%20COM27%3C%2FP%3E%3CP%3EERROR%20memtool.common.base_test%20Application%20load%20ended%20with%20exception%3A%20Download%20incomplete%20due%20to%20configuration%20error!%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2139000%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Config%20Tools%20v26.06%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2139000%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F105311%22%20target%3D%22_blank%22%3E%40simonng%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EFor%20the%20latest%20Config%20Tool%20version%2025.06%2C%20we%20only%20support%20imx95%20chip%20B0%20version%2C%20i%20think%20your%20chip%20is%20also%20A1%20or%20A0%20version%2C%20you%20need%20to%20use%20the%20before%20version%20tool%20run%20the%20DDR%20relate%20test%20of%20i.MX95.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EB.R%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
