Config Tools for i.MX - Change Functional Group
1,055 次查看
daneduplooy
In Config Tools for i.MX, is it possible to switch pins between functional groups? If so then how is this done? Or is it necessary to un-route the pin and then re-route it again in the new functional group?
1 回复
1,044 次查看
riteshmpatel
Hi @daneduplooy,
I hope you are doing well.
One can click on any particular pin and you will see the possible muxing options from different functional groups. One can select any particular functional group and that particular pin would be routed to the selected function.
Thanks & Regards,
Ritesh M Patel
