Altium Design Files for i.MX 8M Nano EVK (8MNANOD4-EVK)
NARC50
I am using a i.MX 8M Nano in a design and would like to reference the design files for the i.MX 8M Nano Evaluation Kit. I use Altium and do not have access to Allegro to convert to a format usable by Altium. Would you be able to send me the Altium compatible files for the evaluation kit?
Thanks!
riteshmpatel
Hi @NARC50,
I hope you are doing well.
One can download the Cadence format files from our website and convert them to Altium-compatible format with a converter provided by Altium. For details, please consult with the Altium support team.
Thanks & Regards,
Ritesh M Patel
NARC50
Thank you @riteshmpatel. I have downloaded the Cadence files, but unfortunately I do not have a Cadence license. From my understanding, the ASCII format design is required to be able to directly import into altium. Since the ALG and the DRA files are not available in the design files, I don't believe that an import is possible without a Cadence license. Maybe I am missing something?
@NARC50
riteshmpatel
Hi @NARC50,
One may consult with the Altium support team to know the detailed procedure to convert the files.
Thanks & Regards,
Ritesh M Patel
