Compiling ATF with SPD support
5,577 次查看
borisshapiro
Hi.
I am trying to load op-tee os in u-boot stage on imx8m mini.
But when I compile ATF from imx-atf repository with option SPD=opteed, the board is stuck after SPL stage before loading uboot.
Can someone post instructions on how to load op-tee os in u-boot stage?
Kind Regards
标记 (2)
7 回复数
5,297 次查看
Csongor
Hi Igor!
I would also be interested in the builds steps, if you could provide them to me, I'd really appriciate it!
5,468 次查看
igorpadykov
Hi Boris
build steps were provided via mail.
4,805 次查看
FanWang0707
Can the  build steps be provided to me? thanks!
4,994 次查看
marcuspe
Hi igorpadykov,
Could I also please get the instructions. Thank you very much!
5,158 次查看
pierrelouis
Hi igorpadykov
Can the build steps be provided to me? Thanks!
Best Regards.
5,468 次查看
492895314
hi igorpadykov
Can the  build steps be provided to me? thank you very much!
5,468 次查看
kk163
hi igorpadykov
