Clutter build errors on the i.MX53 QSB
794 次查看
SeanMcCune
I'm trying to build clutter and I'm getting the following errors:
checking GLES/gl.h usability... no
checking GLES/gl.h presence... no
checking for GLES/gl.h... no
configure: error: Unable to locate require GL header
error: Bad exit status from /home/lucid/ltib/tmp/rpm-tmp.50119 (%build)
I found the page at the following link about it: (Freescale.com Link)
The clutter GUI package requires manual installation of headers before building. The MBX OpenGL ES package does not contain the GLES headers which clutter requires to compile.
Fix / Work around:
Download headers from such places as http://www.khronos.org/opengles/spec/.
On the host, before building clutter, put the headers in the LTIB rootfs directory so that the files are in usr/include/GLES/.
For example:
cd ltib/rootfs/usr/include
tar zxf GLES.tar.gz
ls GLES/gl.h GLES/egl.h
I did all that. No change. Has anybody gotten Clutter to build?  My ultimate goal is to run Clutter in a frame buffer without X.
Thanks in advance for any help!
标记 (2)
0 回复数
