Close the qt demo compiled by yocto
2548903578
The kernel source code compiled by yocto will directly run the official qt demo when the screen is working normally. How to close it? What files need to be modified?
jimmychan
You could compile the image (without QT) in Yocto BSP.
2548903578
Hi,jimmychan
  I think it should be the easiest way to close the official qt demo and run my own qt program now, but now I don't know how to close the official qt demo.
jimmychan
You could search the .bb file of the "image name" you build in yocto. Then there is something like qtbase bb file for building the QT. Then you could search the "gui" option in the content of bb file. Remove the "gui" option from the building.
2548903578
Hi,jimmychan
 Thank you for your reply, if I use the bsp without qt, will the qt program not be able to run normally?
