Chromium / Wayland Issue with IMX8MM
thom
Hay Guys,
i have the following issue.
I build the L4.14.78-1.0.0 Yocto (current Master) with the Chromium-ozone-wayland browser and got the following problem.
If i Start the image and try to start Chromium. Its not possible to run it. See my attached log
Bio_TICFSL
For the error "Segmentation Fault" I guess this is memory issue. However if you modify wayland you must be chek why the issue.
thom
I think its no memory issue, there is a problem with the wayland and the display configuration. But i dont know how to fix
thom
Hay,
but why NXP give a guide in the "i.MX_Yocto_Project_User's_Guide" to Install Chromium on xwayland... ?
Bio_TICFSL
My mistake Chromium is supported, but you have problem with memory alignment.
Bio_TICFSL
Hi Thomas,
There is no support of chromion on wayland.
