Change the board configuration of u-boot and bitbake
1,921 次查看
kimhyun
Hello everybody.
I'm working with SabreSD Board now.
and, I will get the customised board from SabreSD.
So I made a board specific configuration for customised board.
I can change configuration using this command 'make customised-board_config' boot source code.
but, I don't know how to change conf. on Yocto build system. (ex. bitbake u-boot-imx -c compile)
Plz, give me some ideas.
Thanks, in advance.
标签 (3)
1,057 次查看
alejandrolozan1
The below discussion explains the general steps you would need. Basically you have to create a new layer for your custom board.
Modify u-boot in Yocto
/Alejadro
