Capture audio data fail by tinycap
2,813件の閲覧回数
kennychou
Hi all,
I would like to use SSI 1 to capture audio data in I2S slave mode and format as below:
Capturing sample: 1 ch, 8000 hz, 16 bit
but got all zero data when using tinycap.
I found there is no data in SRXn but got data in RFCNTn,
please help to show me the way to debug it.
Dump registers of SSI 1:
STX0      REG 0 = 0
STX1      REG 4 = 0
SRX0      REG 8 = 0
SRX1      REG c = 0
SCR        REG 10 = 1115
SISR       REG 14 = f013
SIER       REG 18 = 1d035f7
STCR      REG 1c = 38d
SRCR      REG 20 = 38d
STCCR    REG 24 = e100
SRCCR    REG 28 = e100
SFCSR    REG 2c = b0ddc0dd
STR         REG 30 = 1103
SOR         REG 34 = 0
SACNT     REG 38 = 0
SACADD  REG 3c = 0
SACDAT   REG 40 = 0
SATAG     REG 44 = 0
STMSK     REG 48 = 0
SRMSK     REG 4c = 0
SACCST   REG 50 = 0
SACCEN   REG 54 = 0
SACCDIS  REG 58 = 0
BR,
Kenny
3 返答(返信)
2,489件の閲覧回数
kennychou
Hi igor,
Got it , thank you very much.
Kenny
2,489件の閲覧回数
Hi Kenny
in general debugging could be done starting with drivers
described in Linux Manual in documentation on
http://www.nxp.com/products/microcontrollers-and-processors/arm-processors/i.mx-applications-process...
and AN4553 Using Open Source Debugging Tools for Linux on i.MX Processors
http://www.nxp.com/assets/documents/data/en/application-notes/AN4553.pdf
2,489件の閲覧回数
kennychou
Hi all,
Please ignore this question since I had found hardware issue on my platform.
Kenny
