Cannot interface an SDIO device with usdhc2
eren_yilmaz
Hi!
I am trying to set up a WiFi module on the second SD interface, however, the process gets stuck in trying to initialise the card with different frequencies. The messages I am getting are
mmc1: mmc_rescan_try_freq: trying to init card at 400000 Hz
mmc1: mmc_rescan_try_freq: trying to init card at 300000 Hz
mmc1: mmc_rescan_try_freq: trying to init card at 200000 Hz
mmc1: mmc_rescan_try_freq: trying to init card at 100000 Hz
The WiFi SD interface works perfectly fine with the first SD interface i.e. usdhc1, I have double checked for any overlapping key assignments for SD2, also tinkered with PAD drive characteristics,but no luck.
My device tree entry for usdhc2 is
&usdhc2 {
    pinctrl-names = "default";
    pinctrl-0 = <&pinctrl_usdhc2>;
    bus-width = <4>;
    no-1-8-v;
    cd-gpios = <&gpio7 3 GPIO_ACTIVE_LOW>;
    fsl,wp-controller;
    status = "okay";
pinctrl_usdhc2: usdhc2grp {
        fsl,pins = <
            MX6QDL_PAD_SD2_CMD__SD2_CMD        0x070b1
            MX6QDL_PAD_SD2_CLK__SD2_CLK        0x070b1
            MX6QDL_PAD_SD2_DAT0__SD2_DATA0        0x070b1
            MX6QDL_PAD_SD2_DAT1__SD2_DATA1        0x070b1
            MX6QDL_PAD_SD2_DAT2__SD2_DATA2        0x070b1
            MX6QDL_PAD_SD2_DAT3__SD2_DATA3        0x070b1
            MX6QDL_PAD_SD3_CLK__GPIO7_IO03        0x170b0 /* SD2 CD */
Here are the more detailed logs. Fail is at CMD5...
Thanks a lot!
mmc1: clock 0Hz busmode 2 powermode 1 cs 0 Vdd 21 width 0 timing 0
sdhci-esdhc-imx 2194000.usdhc: change pinctrl state for uhs 0
sdhci-esdhc-imx 2194000.usdhc: Initial signal voltage of 3.3v
mmc1: clock 400000Hz busmode 2 powermode 2 cs 0 Vdd 21 width 0 timing 0
sdhci-esdhc-imx 2194000.usdhc: desired SD clock: 400000, actual: 386718
mmc1: starting CMD52 arg 00000c00 flags 00000195
mmc1: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
sdhci [sdhci_irq()]: *** mmc1 got interrupt: 0x00010000
mmc1: req done (CMD52): -110: 00000000 00000000 00000000 00000000
mmc1: starting CMD52 arg 80000c08 flags 00000195
/soc/aips-bus@02100000/usdhc@0219c000: voltage-ranges unspecified
sdhci [sdhci_add_host()]: mmc2: Auto-CMD23 available
mmc1: clock 400000Hz busmode 2 powermode 2 cs 1 Vdd 21 width 0 timing 0
mmc1: starting CMD0 arg 00000000 flags 000000c0
sdhci [sdhci_irq()]: *** mmc1 got interrupt: 0x00000001
mmc1: req done (CMD0): 0: 00000000 00000000 00000000 00000000
mmc1: starting CMD8 arg 000001aa flags 000002f5
mmc1: req done (CMD8): -110: 00000000 00000000 00000000 00000000
mmc1: starting CMD5 arg 00000000 flags 000002e1
mmc1: req failed (CMD5): -110, retrying...
mmc1: req done (CMD5): -110: 00000000 00000000 00000000 00000000
mmc1: starting CMD55 arg 00000000 flags 000000f5
mmc1: req done (CMD55): -110: 00000000 00000000 00000000 00000000
mmc1: clock 400000Hz busmode 1 powermode 2 cs 0 Vdd 21 width 0 timing 0
mmc1: starting CMD1 arg 00000000 flags 000000e1
mmc1: req done (CMD1): -110: 00000000 00000000 00000000 00000000
mmc1: clock 0Hz busmode 2 powermode 0 cs 0 Vdd 0 width 0 timing 0
mmc1: clock 300000Hz busmode 2 powermode 2 cs 0 Vdd 21 width 0 timing 0
sdhci-esdhc-imx 2194000.usdhc: desired SD clock: 300000, actual: 281250
mmc1: clock 300000Hz busmode 2 powermode 2 cs 1 Vdd 21 width 0 timing 0
mmc1: clock 300000Hz busmode 1 powermode 2 cs 0 Vdd 21 width 0 timing 0
mmc1: clock 200000Hz busmode 2 powermode 2 cs 0 Vdd 21 width 0 timing 0
sdhci-esdhc-imx 2194000.usdhc: desired SD clock: 200000, actual: 193359
mmc1: clock 200000Hz busmode 2 powermode 2 cs 1 Vdd 21 width 0 timing 0
mmc1: clock 200000Hz busmode 1 powermode 2 cs 0 Vdd 21 width 0 timing 0
mmc1: clock 100000Hz busmode 2 powermode 2 cs 0 Vdd 21 width 0 timing 0
sdhci-esdhc-imx 2194000.usdhc: desired SD clock: 100000, actual: 96679
mmc1: clock 100000Hz busmode 2 powermode 2 cs 1 Vdd 21 width 0 timing 0
mmc1: clock 100000Hz busmode 1 powermode 2 cs 0 Vdd 21 width 0 timing 0
Labels (2)
Hi Eren
host sends CMD5 prior to the CMD55/ACMD41 pair, and thus would receive a valid OCR in
response to CMD5 and continue to initialize the card.
If the I/O portion of a card has received no CMD5, the I/O Section remains inactive and
shall not respond to any command except CMD5.
So one can attach logic analyzer and check where error happens, my be there is poor
signal quality due to layout.
eren_yilmaz
Hello Igor,
Thank you for your response.
I have checked the signals and as you say it fails to initialize where the SYS_CTRL register, SDCLKFS frequency select field gets set to 40 (it should be 10). Triying different settings, now I am getting
"MMC:   Card did not respond to voltage select!".
Any suggestions?
Hi Eren
"MMC:   Card did not respond to voltage select!". means that host
does not support suggested SD voltages. One can look at SDIO
specificaion for more details.
Simplified Specifications - SD Association
usdhc2 sdio example can be found in technexion board
linux-imx-tn/imx8mq-pico.dtsi at tn-imx_4.14.98_2.0.0_ga-wip-mipi2lvds · TechNexion-customization/li...
