I'm having some troubles getting my display to work (TX18D211VM0BAA) with the i.MX7ULP. The display is using LVDS for communication, thus I have place a MIPI_DSI-LVDS bridge (SN65DSI83TPAPRQ1) to convert the signals for the display.
When booting Linux, it all seems fine:
root@imx7ulpevk:/# dmesg | grep -i -E "mipi|sn65|lcdif|video|drm|panel"
[ 0.085332] platform 40a90000.mipi_dsi: Fixed dependency cycle(s) with /bus@40000000/lpi2c4@402b0000/sn65dsi83@2c
[ 0.134710] platform 40a90000.mipi_dsi: Fixed dependency cycle(s) with /bus@40000000/lpi2c4@402b0000/sn65dsi83@2c
[ 0.135162] i2c 2-002c: Fixed dependency cycle(s) with /bus@40000000/lpi2c4@402b0000/sn65dsi83@2c/panel@0/ports/port@0
[ 0.135253] i2c 2-002c: Fixed dependency cycle(s) with /bus@40800000/mipi_dsi@40a90000
[ 0.142246] videodev: Linux video capture interface: v2.00
[ 0.146419] MIPI CSI2 driver module loaded
[ 0.564469] mipi_dsi_northwest 40a90000.mipi_dsi: i.MX MIPI DSI driver probed
[ 2.187945] [drm] Initialized vivante 1.0.0 20170808 for 41800000.gpu on minor 0
[ 7.157978] systemd[1]: Starting Load Kernel Module drm...
[ 14.327604] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 14.514570] systemd[1]: Finished Load Kernel Module drm.
though at the very end of the boot process I do get a notice the the Psplash failed to start:
[FAILED] Failed to start Terminate Psplash Boot Screen.
See 'systemctl status psplash-quit.service' for details.
Below is the snippets from the dts, that shows the configuration of the bridge and panel.
Do anyone have some ideas why nothing is shown on the display? Is there something that I'm failing or missing to do?
&lpi2c4 {
#address-cells = <1>;
#size-cells = <0>;
clock-frequency = <100000>;
pinctrl-names = "default", "sleep";
pinctrl-0 = <&pinctrl_lpi2c4>;
pinctrl-1 = <&pinctrl_lpi2c4>;
status = "okay";
dsi_lvds_bridge: sn65dsi83@2c {
compatible = "ti,sn65dsi83";
reg = <0x2c>; /* 7-bit I2C address */
pinctrl-names = "default";
pinctrl-0 = <&sn65dsi83_enable_pins &sn65dsi83_irq_pins>;
status = "okay";
interrupt-gpios = <&gpio_ptc 2 GPIO_ACTIVE_LOW>;/* PTC2 */
enable-gpios = <&gpio_ptc 3 GPIO_ACTIVE_HIGH>; /* PTC3 */
ti,dsi-lanes = <2>; /* Use two DSI lanes, DA0 and DA1 */
ti,lvds-format = <1>;
ti,lvds-bpp = <18>; /* 6-bit per color -> 18 bpp */
ti,lvds-channels = <1>;
ti,width-mm = <152>;
ti,height-mm = <91>;
video-mode = <1>;
/* dsi traffic mode (0=non-burst,1=sync-event,2=burst) */
dsi-traffic-mode = <0>;
panel: panel@0 {
compatible = "panel-simple";
reg = <0>;
label = "lvds-panel";
display-timings {
native-mode = <&timing0>;
timing0: timing0 {
clock-frequency = <33300000>; /* Clock freq. 33.3 MHz */
hactive = <800>;
vactive = <480>;
hsync-len = <128>; /* thp (HS pulse) ≈ 128 */
hback-porch = <10>; /* thb */
hfront-porch = <118>; /* thf */
vsync-len = <1>; /* tvp~1 */
vback-porch = <9>; /* tvb (tvp+tvb = 10 -> tvb=9) */
vfront-porch = <35>; /* tvf */
de-active = <1>;
hsync-active = <0>;
vsync-active = <0>;
pixelclk-active = <0>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
endpoint {
panel_ep: endpoint {
/* left empty: this is the panel end-point */
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
lvds_bridge_in: endpoint {
remote-endpoint = <&dsi_out>; /* DSI host endpoint on &lcdif */
data-lanes = <0 1>;
port@1 {
reg = <1>;
lvds_bridge_out: endpoint {
remote-endpoint = <&panel_ep>; /* link to panel node */
&mipi_dsi {
#size-cells = <0>;
pinctrl-0 = <&pinctrl_mipi_dsi_reset>;
pinctrl-1 = <&pinctrl_mipi_dsi_reset>;
lcd_panel = "TX18D211VM0BAA";
resets = <&mipi_dsi_reset>;
status = "okay";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
dsi_out: endpoint {
remote-endpoint = <&lvds_bridge_in>;
data-lanes = <0 1>;
attach-bridge;
